Hi All!
As the title says, how do I get my code to write x and y on every line? Right now if the coordinates are the same it doesn't repeat the number. Is it the GPP or mac file I edit?
Thank you!
Hi All!
Thank you!
Use the "change ()" command. refer your GPP document for the details
