587,426 active members*
4,373 visitors online*
Thread: Gouge
Results 1 to 4 of 4
    Feb 2009
    214
    Gouge
    I break 1/32 carbide ball nose bits too much.
    I don't think it is speed or depth of the tool, I think it is running into material at some point.
    on the cut that it broke I started with 1/16 BN, Z level rough and Equidistant, not leaving any in allowance in either cut.
    then the next with the 1/32 I used the Advance rough using the rest roughing. and entered the previous cutter.
    so I read about the gouge but havn't figured out how to use this. I don't know what to look for, But is that what I need to learn to find where my problem is? I assume that is what that is for.
    In the help it says:
    Navigation
    To access the Advanced Options for Gouge Checking dialog box:
    •Click Advanced at the bottom of the Gouge Check tab.
    I havn't found yet, the only thing I see is in the feature setup
    so i am kind of lost, is there a video to show this?
    David L. Aery
    www.hooksolutions.com
    Jun 2008
    1838
    Re: Gouge
    David
    Does it have to be a Carbide tool? What are you cutting? Sometimes it is better to use an HSS cutter, Carbide are very brittle so snap more easy than an HSS tool which wil have a bit more flex to it.
    Regards
    Rob
    Feb 2009
    214
    Re: Gouge
    Thanks, I am cutting aluminum. I'll try the HSS
    David L. Aery
    Dec 2011
    295
    Re: Gouge
    Rest remachining needs minimum radius and tool offset recalculated. Dont drive a corner.
  1. gouge check , is there something i'm not getting here ?
    By phucrobusl in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-03-2018, 07:08 PM
  2. Text Gouge
    By RAF. in forum BobCad-Cam
    Last Post: 04-18-2015, 04:34 AM
  3. Gouge check - drilling
    By sebastian_dogar in forum PTC Pro/Manufacture
    Last Post: 02-21-2011, 06:14 PM
  4. Collision / Gouge check
    By coykiesaol in forum Mastercam
    Last Post: 12-25-2010, 07:03 PM
  5. Gouge Help
    By ninewgt in forum Uncategorised CAM Discussion
    Last Post: 09-04-2003, 01:31 PM
