587,421 active members*
3,281 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Good flood coolant that doesn't cause rust?
Results 1 to 2 of 2
    Feb 2011
    53
    I am wanting to start using the flood cooling on my mill but I remembered that last time I used flood cooling it started to rust my bed, vice etc. and that was in dry Arizona! Now I am in the midwest and have to have something better at fighting rust as the basis of my coolant. What are the best econimial options?
    God bless...
    Mark
    Jul 2005
    12177
    What concentration were you diluting the coolant? Many times the manufacturers recommendations are to dilute 1 in 20, i.e. a 5% mixture. This may be perfectly okay for cooling and lubricating the cutting tool but when the water evaporates away there is not enought coolant film left on metal surfaces to prevent rusting. Boost the concentration to somewhere between 10 and 15% and there should be no rusting.
  1. What flood coolant is good for Taig Enclosure
    By Menacer in forum Taig Mills / Lathes
    Last Post: 02-13-2013, 05:59 PM
  2. Flood coolant
    By vidio1 in forum Knee Vertical Mills
    Last Post: 02-03-2012, 08:29 AM
  3. flood coolant
    By FUBAR62172 in forum Community Club House
    Last Post: 06-05-2010, 09:32 PM
  4. NM-135 and Flood coolant
    By David Da Costa in forum Novakon
    Last Post: 02-11-2010, 04:18 PM
  5. good flood coolant found.
    By nervis1 in forum MetalWork Discussion
    Last Post: 12-23-2004, 11:16 PM
