Hello people..I would ask if there are some option on Mach3 that when I finished my work job and want the X&Y Axis to Go To Zero (home position) except Z Axis?
There are several ways you can get Mach3 to do it, but there is no built in option for it.
The simplest way is to add it to your g-code.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Hello ,wakedabed
Good day
Yes , Ger21 said is right , change g-code is a way , you open the g -code by notepad , then last two line should be M05 ( Spindle stop) M30 (program end ), before M05 , you input( goo x 0 y 0 ), it is ok
Frank
I am sorry , it is G00 (Zero),
