587,481 active members*
2,934 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > GiLdemeister Fanuc NEF 480 - HELP!
Results 1 to 2 of 2
    Mar 2007
    9
    I purchased an old ( late 80s ?) NEF 480 Lathe. It has a dead i/o board. will not power up. when I powered up the machine, the power section ( main resistors/diodes etc where power comes in) got very hot- the main resistor (white ceramic) was glowing :-( - I would like to get the machine working in it's original form but will consider updating the controls. Any one up for a challenge?
    Willling to hire a tech to come in an do an evaluation. I'm in Los Angeles...
    daveallen Guest
    Sorry I cant help much but if you decide to update the controls I would be interested in buying the spare parts for my machine.
  1. Gildemeister CNC-Lathe NEF 480
    By pestana1957 in forum Uncategorised MetalWorking Machines
    Last Post: 09-01-2010, 06:48 PM
  2. gildemeister lathe
    By roni21702 in forum DNC Problems and Solutions
    Last Post: 03-08-2010, 06:09 PM
  3. CNC lathe Gildemeister NEF 480
    Last Post: 05-18-2008, 02:34 AM
  4. on Gildemeister speed 12 -7 hard material machining
    By Ashu in forum Hard / High Speed Machining
    Last Post: 10-16-2006, 01:14 PM
