As I've documented in my previous thread, my X2 accuracy is quite poor (on the order of a 1/10" off at times). This is likely my fault in how I put it together. To be honest, I've not touched the machine in months as this process scares me for lack of a better term. Every time I've touched the machine, I've ended up making it worse. In the last few months, I spent my time getting good at CAD and such and now I'm up against a wall. I need to start making chips this week or I won't be able to finish my robotics project in time for the competition I'm attending in a few months.
So, back to square one. I'm trying to fix the accuracy problem. I've torn the machine all down to just the Y-axis components, re-tightened them down, and then lubricated it all up. I've attached a dial test indicator to the chuck and then jogged off and on to see if the same value is consistently repeatable. As best I can tell, it is. Here is a video showing what I've done:
[ame="http://www.youtube.com/watch?v=62mPXXWuo_I"]YouTube- Y Axis Test #1[/ame]
So my question is: what should I check next? I'm trying to put each axis to bed as I go. The Y axis didn't appear to be much of the problem the first time around but I figure it's best to test it and be sure. Also, what should I be putting locktite on? Someone suggested locktite before but I've not used it on anything yet for fear of putting it on the wrong part. Please also remember I'm a total neophyte so try and keep it simple Thanks much for any help!
-Mike
