587,087 active members*
2,954 visitors online*
Results 1 to 2 of 2
    Aug 2014
    8
    General Specs
    from what i gather so far on a cnc router/mill i need a spindle motor of at least 800W and a repeat tolerance of no more than .01 Will be used for wood, plastic, aluminum, silver. What would be some other min specs to look for.
    35538
    Re: General Specs
    Smaller spindles tend to use collets with a smaller capacity. Make sure the collets can hold the largest tools you'd want to use.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. X3 specs help
    By fourxblz in forum X3/SX3/G0619/G0463
    Last Post: 03-30-2013, 02:27 AM
  2. VF-2ss specs?
    By extanker59 in forum Haas Mills
    Last Post: 05-19-2011, 08:14 PM
  3. Need help with the specs
    By Swathi in forum DIY CNC Router Table Machines
    Last Post: 02-26-2011, 04:13 AM
  4. Stepper Specs (Was Servo Specs)
    By plexer in forum Stepper Motors / Drives
    Last Post: 09-29-2005, 03:28 PM
  5. Servo Specs...
    By CarveJunky in forum Servo Motors / Drives
    Last Post: 05-31-2005, 02:03 PM
