587,812 active members*
3,346 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko g540 ground pin burned out
Results 1 to 9 of 9
    Sep 2016
    37
    Hi I've been running a gecko g540 for almost two years now and just last weekend I couldn't get a red light on it much less green. After a bit of probing around I found the the circuit board ground and my ground wires have no continuity. The green pin tray plastic has a small amount of brown colouration around the ground pin. Has anyone else had this problem? Something obviously burned out between the terminal and the circuit board. Any ideas what the cause would be? I have a surge protector on the setup so I doubt it would be surges. Obviously there was a lot of current in there at some point. Also any ideas on how I could fix the screw terminal so I don't have to solder a wire directly to the gecko?
    Mar 2007
    2083
    Re: Gecko g540 ground pin burned out
    its the first I have read of a G540 having burnt connectors but
    Phoenix Contact connectors burning up are found on a number of threads
    like this on a Tormach machine's Leadshine 3ND883 or Tormach driver 31234
    examples of burnt connector
    Attachment 422306
    Attachment 422304
Name:	LEADSHINE 3ND883.jpg
    the problem can be found with any product using this connector
    see post 13
    https://www.cnczone.com/forums/torma...-toilet-2.html
    one possible solution if you don't send the G540 back to Geckodrive could be to solder a wire directly to the board
    from another cnczone post
    https://www.cnczone.com/forums/torma...connector.html
    John
    35538
    I've also never heard of this on a G540, but I've seen a handful of posts showing it on other Gecko drives.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2016
    37
    Hmm so it seems its not common! I think I may just solder a wire directly to the board then. Hopefully more connectors don't go on me.
    Mar 2007
    2083
    In addition to the ground/0V pin 12 how does the +18V to 50V supply pin 11 look ?
    pins 1 to 10 pass a low current and should be OK
    the only other high current connections are the 9 way D-type sockets for the motor connections
    its important the supplied 9 pin plugs are used
    most D-type plugs found online are low current connectors and will over heat
    for example a 3A ebay connector
    https://www.ebay.co.uk/itm/DB9-DIY-9....c100005.m1851
    one 5A connector I found from RS components
    https://uk.rs-online.com/web/p/solde...ctors/0472843/
    https://docs-emea.rs-online.com/webd...6b816bffd1.pdf
    John
    Jan 2005
    15362
    Quote Originally Posted by Keonfrey View Post
    There must be over current draw to cause this to happen or there G540 needs better connectors
    Mactec54
    Sep 2016
    37
    Quote Originally Posted by john-100 View Post
    John
    Yeah all the other connections look fine! That is interesting though! Thanks for the info John!
    Aug 2005
    1105
    Just a thought. Have you checked the G540 onboard fuse?
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
    Jan 2007
    467
    The most likely cause of a burned connector on the GND pin is a loose connection. The increased resistance from an incomplete connection on the header can lead to heating on the connector. I'd recommend sending the G540 back for evaluation and repair so we can check if anything else has been damaged.
    Marcus Freimanis
    www.geckodrive.com
  1. G540 ground questions
    By pbmwco in forum Gecko Drives
    Last Post: 01-20-2024, 10:40 AM
  2. Replies: 1
    Last Post: 08-27-2018, 08:41 AM
  3. Burned Gecko G540- Power Supply or DB9 cables?
    By huh2 in forum Gecko Drives
    Last Post: 01-16-2015, 04:58 AM
  4. Replies: 1
    Last Post: 01-03-2014, 08:58 AM
  5. G540 4 axis driver ground ?
    By hanau in forum Benchtop Machines
    Last Post: 11-22-2013, 10:02 AM
