587,651 active members*
3,634 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko G540 with 6 wire steppers
    Feb 2011
    0
    Does anyone have or know the optimum wiring for 6 wire steppers to a G540 board. Currently I have the two center ports wired to power supply positive and the 4 outer ports wired to the gecko. Except for motor heating at idle this seems to work. In looking at 4 wire configurations it appears all voltage is going through the G540 instead of just the grounds. Could my wiring configuration be bypassing the current set resistor mounted at the G540 end of my cables?
    Jan 2010
    2141
    The hookup that you are using is not correct for hooking up a 6-wire motor to a G540. The G540 is designed to handle 4-wire motors (or 4 of the 6 wires of a 6-wire motor). You should not be connecting the center taps to a positive voltage source. Rather, you will want to hook up "half coils" or "full coils" to the G540, and tape off the extra wire from each winding.
    There is a gecko document that illustrates the two different wiring options - Look at Figure 9 and Figure 10 of the following document:
    http://www.geckodrive.com/ark-2/support.html
    Feb 2011
    0
    Thanks Doorknob, exactly what I was looking for.
  1. Need steppers for Gecko G540?
    By The CNC Man in forum Stepper Motors / Drives
    Last Post: 12-19-2016, 12:21 AM
  2. Replies: 29
    Last Post: 01-16-2015, 05:35 AM
  3. Replies: 5
    Last Post: 06-26-2011, 05:28 PM
  4. Ok.... I like the Gecko G540, but...
    By Bob La Londe in forum SmoothStepper Motion Control
    Last Post: 06-01-2011, 11:55 PM
  5. Steppers for Gecko G540
    By orion63 in forum DIY CNC Router Table Machines
    Last Post: 05-24-2011, 07:13 PM
