587,300 active members*
3,166 visitors online*
    Jul 2005
    19
    Gecko 320 retrofit
    I have puchased an Eagle knee mill with a crapped out Anilam Crusader M control. This machine is very similar to a bridgeport series 1. I have been looking at several different ways to retrofit and I like the price of the gecko drives. My question is this will gecko 320's work with these servos(see attached picture)? If you can't see the info on the name plate of the servo it reads as follows.
    Max. current Continuous 5.8a
    Max. current Peak 30a
    Torque Stall 3nm CONT.
    Max speed 2400rpm
    Max Voltage 140vdc
    Insulation Class F 25 deg. C amb
    Tachometer 9.5 V/Krpm
    Any information on this type of retrofit would be a great help.
    Thanks,
    Eric
    Mar 2005
    361
    If they are a brushed type dc motor they should work fine. I have used a lot of them and they are a great drive
    mike
    Apr 2004
    4
    As stated, if they are brushed DC, they will work, just keep in mind that with a max of 80 volts to the Geckos, you will drop the max motor speed too. It should not be a problem though as 1400 rpm is still a very good motor speed.
