Iam a new guy on the block I built a controller using a campbell design breakout board, 3 Gecko 201,8 lead stepper motors input voltage is 36 volts,I thought when you turn the power on to the controller the steppers lock up,mine do not there is a very small amount of lock up I still can turn the shaft by hand I tried everything I know is there someone who can lead me in the correct direction.
