587,287 active members*
4,384 visitors online*
Results 1 to 4 of 4
    May 2013
    0
    gCode to Leetro issue
    I'm facing some troubles with NON-opensource & proprietary CNC code file from Leetro.
    I need to cut drawings from Eagle CAD and I find no way of doing so. Can some one explain me how to do that ?
    My Leetro controller is 6525 & Lasercut53.
    From eagleCad I can export in PS, PDF, GERBER, gCode but no DXF.
    Any help is really appreciated.
    May 2013
    0
    Ok, a little patience and some hours give me one answer:
    1) Export from eagle in EPS (from CAM option)
    2) Import in Inkscape and then Export from Inkscape in DXF (cutter)
    3) Import in LaserCut53
    There are some duplicated lines with this procedure, I will keep looking why is this happening.
    Try the "unite lines" feature in lasercut53. it can sometimes remove duplicate lines. YMMV.
    Jul 2014
    19
    Re: gCode to Leetro issue
    Lasercut has a data-check option.
    use it to find overlapping data
  1. PLEASE HELP IF YOU CAN!!!!! Leetro MPC6525
    By TheWorkshopGuy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-09-2020, 06:37 AM
  2. Leetro PAD03-E
    By cinematic2 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-11-2014, 09:01 AM
  3. Anybody had experence with - Leetro
    By Danceswithcubes in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-01-2011, 12:51 PM
  4. G540 .xml / Mach3 / gcode error issue
    By forrest39 in forum Benchtop Machines
    Last Post: 06-30-2010, 12:11 AM
  5. Mach 3 issue - possbily arc gcode related
    By fseger in forum Mach Software (ArtSoft software)
    Last Post: 05-28-2008, 11:35 PM
