Hi
I have a Midwell with FANUC O-M controller.
In MDI-mode I run:
G90 G00 X10 Y10
Instead of moving absolute it's moving incremental, there is no difference if I run with G91.
Which parameters can affect this?
Thanks!
Hi
In MDI-mode I run:
G90 G00 X10 Y10
Thanks!
Have you tried putting the G90 or G91 on a line by itself? ... like this :
G90
G00 X10.00 Y10.0
G91
G00 X10.00 Y10.00
... I have seen this resolve the issue many times.
Chec out our Real World Machine Shop Software at Kentech Inc. - Real World Machine Shop and CNC Software
Including Conversational CNC Programming Software for Milling & Turning
Yes. That gives the same result.
This is from the MDI Operation section of the 0M-C/D manual.
In MDI operation, the setting (absolute) determines whether the
commands are absolute or incremental. The G code (G90/G91) is
ignored.
So, go to the Settings screen and set Absolute to 0 or 1 depending on which mode you want.
