Good Day,
Any help is appreciated......I have a Kiwa Mill with a Fanuc 10m control.
The entire parameter settings had to be restored recently and everything works fine except the G76 Fine Boring Cycle. It will feed down and do the oriented spindle stop at the bottom of the Z move and at that point it should retract in the X- direction via a Q command in the part program. This is set to work in this manner from paramater settings at 6200 and 6240. Parameter 6240 selects the direction and the max amount of Q. The retract at the bottom of the bore will only move in the X positive regardless of the sign entered in the parameter. It used to move in the X- before the system was restored.???????
Again any help is appreciated!!
T.Gorrell
