Chris,
Here is a little more information.
See attached jpg's for more detail.
The trimpot adjusts the motor for the smoothest possible low-speed operation.
Set the motor speed to about 1/4 revolution per second, then turn the trimpot with a insulated screw driver until a distinct null is noted in the motor’s vibration.
This will result in the most even microstep placement for a given motor and power supply voltage.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
