Purchased a used Kitamura HX400ia with Fanuc 16i. How to stop from zeroing out the G54 when reset is pressed.
Thanks,
Kirk
Thanks,
Kirk
Kirk
Do you mean that it puts zeros in the X,Y and Z G54 offsets in the Geometry Offset page, or that it makes G54 the active WCS when you hit reset?
If it's the latter, I think you want to change 1201 bit #7 to 0
WZR Upon reset, the workpiece coordinate system is:
0 : Not returned to that specified with G54
1 : Returned to that specified with G54
Thanks dcoupar, The issue is that when reset is pressed, the G54 offsets are changesd to zeros.
Kirk
