Just got v11 and trying to do some tests, but having some problems with cutter comp as output by the post processor. I have a Dynapath Delta 10 controller. Following is a simple file straight from the post processor for that controller. Just a square with a circle in the middle.
The program seems to run fine until line 185, which is g41 cutter comp left. This controller excepts G40, 41 and 42. But I get an error with g41 in this program.
I run the same program with the offset to none, g40 and the program ran all the way through.
So I'm not sure if it's looking for something before line 185? I also noticed that the post is adding several g codes to the first line, which my manual says there can only be one g command per line.
Can anyone help with this issue?
N5G70G40G17G90G80
N15T1M06
N25S1225M03
N35G00X0.0Y0.0F5.0
N45Z1.969
N55X0.75Y0.0
N65Z0.125
N75G01Z-0.5
N85G03I0.0J0.0
N95G01X0.375Y0.0
N105G03I0.0J0.0
N115G01X0.188Y0.0
N125G03I0.0J0.0
N135G00Z1.969
N145S1225
N155X-2.006Y2.257
N165Z0.125
N175G01Z-0.5
N185G41X1.992Y2.257D1
N195G02X2.242Y2.007I1.992J2.007
N205G01X2.242Y-2.007
N215G02X1.992Y-2.257I1.992J-2.007
N225G01X-2.006Y-2.257
N235G02X-2.256Y-2.007I-2.006J-2.007
N245G01X-2.256Y2.007
N255G02X-2.006Y2.257I-2.006J2.007
N265G40G00Z1.969
N275M30
