I have a simple question (i hope) i am wiring up these drives and done see anywhere about the amps for a 5 volt power supply.
I am using the cnc4pc breakout board C1G.
d1rage5,
200 ma for the drives and breakout board will be sufficient.
You can get the five volts from your P.C.
http://tinyurl.com/l8mlse
Or from a 5 volt adapter.
http://tinyurl.com/m6uul5
Or even a USB power adapter.
http://tinyurl.com/nn3gpo
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
I will be running three of the g201's and i have a few 5v 2amp supplies will they work or would the 2amp kill anything?
as Jeff said , a pc supply or what have you , if its higher amps don't worry about it , if the amperage is below the min then you may have a problem
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
