587,482 active members*
3,430 visitors online*
Thread: G09
Results 1 to 5 of 5
    Oct 2007
    51
    G09
    is there a way to add ignore command to the shift ,rotate, ect. When I use shift to move a part in program I first have to find and replace G09- (check exact stop) to something such as G0000 and the use shift then change G0000 back to G09
    765
    What happens to the G09 block when you use the translate tools? Why do you have to do the find and replace?
    Scott
    Oct 2007
    51
    Sorry for the delay
    When g09 is in the line with g code it will not allow the shift command to shift that code.
    Say i have 10 lines of xy coordinates and place g09 at the beginning of two lines to force a sharp corner it will only shift the coordinates that do not have g09 in the line
    765
    The translation tools will skip any block that contains a group 0 G-Code. Of course, G09 is a group 0 code and so the block is being skipped. I will have to make an exception for G09, but in the meantime you can use the Address Adjustment tool to shift your code.
    Thanks,
    Scott
    Oct 2007
    51
    cool thanks hadn't thought of using address adjust
