587,792 active members*
3,355 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0602 Z-axis lead screw / gearbox removal?
Results 1 to 4 of 4
    Mar 2004
    576
    Question G0602 Z-axis lead screw / gearbox removal?
    I'm a bit unclear on how to get this z-axis shaft out. Even if I were to remove the C-clip (#822), I can't see how the shaft would some out.
    Some please educate me.
    Attachment 458176
    Attachment 458178
    Re: G0602 Z-axis lead screw / gearbox removal?
    It looks like you remove the feed rod, remove the coupler, remove the cover with the three screws on the right end. Do similar on the left end. Then it appears that there's a set screw in the middle boss in the bear box. Pull that out and the shaft should be able to move to the left or right.
    Mar 2004
    576
    Chris,
    Looks like you responded last night, so not sure why I just got an email notice for your response.
    I did get it figured out today. The screw was the part I was missing.
    Thanks!
    That's great. I'm glad you got it figured out.
  1. SL-25 X-axis ball screw removal?
    By NoGoodNolan in forum Mori Seiki lathes
    Last Post: 05-24-2022, 07:08 PM
  2. Replies: 1
    Last Post: 01-18-2017, 07:58 PM
  3. Mazak VQC-20/40B - X axis ball screw removal
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2014, 01:04 PM
  4. G0602 Lathe lead screw deflection
    By Spaceman70 in forum Benchtop Machines
    Last Post: 01-01-2012, 12:11 AM
  5. G0602 X-Axis Ball Screw
    By Flenser in forum Benchtop Machines
    Last Post: 04-12-2011, 03:20 AM
