Hey All,
I have decided to go ahead and do a CNC conversion on my G0602 Lathe. I have ordered all the parts and they should be here in short order.
I already had a G540 based control from another project so I figured I would save some bucks and time and reuse the control I already built.
I plan on switching out the spindle motor for a 2HP AC inverter duty motor and Hitachi sensorless vector drive VFD. Additionally I ordered Arturo's C3 index pulse card from cnc4pc to create a closed loop spindle drive for threading.
I also plan to create a cast iron back plate for a 6 inch 6 jaw run tru chuck. I will be working with thin wall tubing plus I like that type of chuck a lot.
If all goes well I might try to do a tool turret ATC as well based on some plans floating around.
The control I built has a Gecko G540, 48V Meanwell DC Power supply, two 50 volt relays, a smoothstepper, e-stop, and all the inputs and outputs of the G540 are wired to the back panel. I based it loosely on a commercially sold G540 controller.
This is everything I ordered from McMaster
Line Product Ordered Ships Price Total
1 9845T203 Aluminum High-Misalignment Spider Coupling Hub, 3/8" Bore, 1" Outside Diameter 2
each Monday morning
16.30
each 32.60
2 9845T201 Aluminum High-Misalignment Spider Coupling Hub, 1/4" Bore, 1" Outside Diameter 2
each Monday morning
16.30
each 32.60
3 9845T14 Red Shore 98A Spider for 1" OD, Aluminum High-Misalignment Spider Coupling Hub 2
each Monday morning
6.78
each 13.56
4 5966K26 Ball Screw, 5/8" Diameter, 13/64" Lead, 3' Length 1
each Monday morning
57.33
each 57.33
5 5966K26 Ball Screw, 5/8" Diameter, 13/64" Lead, 1' Length 1
each Monday morning
19.11
each 19.11
6 5966K16 Ball Nut, 5/8" Diameter, 13/64" Lead, 778LB Load Capacity, Square 4
each Monday morning
30.64
each 122.56
7 6680K12 Dual-Load Angular-Contact Steel Ball Bearing, Open, 12MM Shaft Diameter, 32MM Outside Diameter 4
each Monday morning
28.63
each 114.52
8 8476K193 Heat-Resistant Borosilicate Glass, Square, 3/16" Thick, 9" X 9" 1
each Monday morning
28.46
each 28.46
9 96115A420 Metric Zinc-Plated Brass Round Knurled Thumb Nut, M3 Size, .5MM Pitch, 8MM Head Diameter, 6MM Overall H 4
each Monday morning
1.16
each 4.64
10 96115A440 Metric Zinc-Plated Brass Round Knurled Thumb Nut, M4 Size, .7MM Pitch, 10MM Head Diameter, 7MM Overall H 4
each Monday morning
1.49
each 5.96
11 8974K33 Multipurpose Aluminum (Alloy 6061), 1/2" Diameter X 6' Length 1
each Monday morning
15.04
each 15.04
12 8975K781 Multipurpose Aluminum (Alloy 6061), 3/4" Thick, 2" Width, 1' Length 1
each Monday morning
16.02
each 16.02
13 8975K429 Multipurpose Aluminum (Alloy 6061), 1/2" Thick, 4" Width, 1' Length 1
each Monday morning
19.05
each 19.05
14 8975K313 Multipurpose Aluminum (Alloy 6061), 1" Thick X 3" Width X 1' Length 1
each Monday morning
26.37
each 26.37
15 8975K434 Multipurpose Aluminum (Alloy 6061), 1/4" Thick, 5" Width, 1' Length 1
each Monday morning
14.05
each 14.05
Total $521.87
This is everything I ordered from Keling aka Automation Technologies
Motor cable connector
Item# 428 $3.99 USD 4 $15.96 USD
NEMA23 495 oz in, 3A, 1/4” Dual Shaft Stepper Motor (KL23H2100-30-4BM)
Item# 161 $49.95 USD 2 $99.90 USD
This is everything I ordered from Automation Direct
1.0/CFS-2PM30 DISCONNECT SWITCH, FUSIBLE, 2P, MIDGET CLASS, 240 VAC, 30A, UL 508, DIN RAIL
1.0/Y368 AC MOTOR 2HP 1800RPM 145TC 230/460VAC 3-PH ROLL-STEEL MICROMAX
This is everything I ordered from Drives warehouse
1 PWV2-20-1 SENSORLESS VECTOR DRIVE
O/P: 2HP, 230VAC, 8A
WJ200-015SF
283.00 283.00
