the lathe i am using is a binns and berry with a fagor 8025ts controller
i new there was something wrong with the system as when you press the x+ on the controller the slide moves in x- out(programing x+ moves in the right direction i think its for a rear toolpost and mine is a front) the hand wheel moves in the right direction my main problem is using a g68 canned cycle it will rough out alright (with g02 and g03) but error comes up on final pass so the p7 line i put in 0 so no final pass and wrote a separate final pass and i noticed that the g02 line was doing a g03 and vice versa so i changed my g02s to go3 and it worked
i can only think the machine is set up for a rear toolpost but i dont understand how the roughing cycle is alright
