587,214 active members*
4,467 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Autodesk Post Processors > Fusion 360 Post for HAAS SL20 Lathe
    Sep 2016
    5
    Hi there,
    Does anybody have a working post processor for a HAAS SL20 lathe for autodesk fusion 360 i can get an ST20 from the posts page but it seems slightly different to the code that is used in the SL20.
    The Lathe has a rear turret toolchanger
    Kind Regards
    Re: Fusion 360 Post for HAAS SL20 Lathe
    what does not work ? the Fusion 360 post processors are relative easy to modify except more difficult stuff like life tooling.
    I programm a Doosan 220LY with a C and Y axis with Fusion 360 and for this I modified a post processor for a Haas ST20 SSY.
    Mar 2014
    44
    Yes, I made a commercial post for a customer in the past for this machine. There are indeed diferences. There are for example no radial drilling cycles possible, and some cycles are different. Also most of them have a livetool holder that runs in reverse (so m3 is m4) The problem is, the documentation for this machine is pretty limited.
    You can contact me if you want to invest in a postprocessor.
  1. Looking for a SolidCAM post processor for a Haas SL20 Lathe
    By Foxtrot308 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-20-2016, 08:43 PM
  2. Haas SL20 lathe toolsetter fault
    By nigelw in forum Haas Lathes
    Last Post: 01-09-2015, 08:41 AM
  3. SL20 Haas Lathe..Worthwhile??
    By bigbobr in forum Haas Lathes
    Last Post: 11-03-2007, 07:38 PM
  4. Haas SL20 'vrs' Hyundi Kia Skt21LM Lathe
    By scappini in forum Haas Lathes
    Last Post: 03-12-2007, 05:27 PM
  5. HAAS SL20 Lathe
    By SGP in forum Haas Mills
    Last Post: 01-04-2007, 11:06 PM
