587,383 active members*
3,789 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > fusion 360 plasma cutting option to mach3
    Trying to use fusion 360 plasma cutting cam but when I post process there is no option for mach 3 plasma, just mill and that one wont work.
    anyone find a way around this or know of any free plasma cams I can use with mach 3.
    My next option is to buy sheet cam.
    Aug 2016
    22
    Re: fusion 360 plasma cutting option to mach3
    Use the torchmate post. modify it to fire the torch with M3 and M5 instead of M50 and M51
    Quote Originally Posted by ProtoXNH View Post
    Cool thanks will try that
  1. Less expensive DIY plasma CNC option than Precision Plasma?
    By PLASMAMONSTER in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-19-2017, 05:05 PM
  2. Replies: 1
    Last Post: 05-05-2017, 05:17 PM
  3. Plasma Cutting Pronest Mach3 and dimensions
    By rockbaba in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-28-2016, 02:00 AM
  4. corner signal in Mach3 for plasma cutting machine
    By larryy1022 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-28-2011, 10:55 AM
  5. constant velocity and power settings in mach3 plasma cutting
    By Knut in forum Waterjet General Topics
    Last Post: 09-28-2006, 04:19 AM
