587,735 active members*
3,503 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Fried Probotix Breakout board or drivers?
Results 1 to 2 of 2
    Jan 2008
    1543
    Hey guys,
    I was just rewiring my 3-Axis ProboStep Stepper Motor Driver Kit and have run into a problem.
    After wiring the motors were turning fine as normal. Then I was using the +5V and GND on the PC side of the breakout board as power source for hall effect limit switches (with inputs on to the isolated side of the board). Unfortunately the +5V and GND wires touched. Now the steppers move erratically and at times without command.
    Has this brief short circuit fried the breakout board?
    I've tried a second PC - same problem.
    Any help is appreciated.
    Jan 2008
    1543
    I confirmed that the breakout board had been fried through swapping the drivers to different ports on the BOB. Multimeter testing also confirmed the problem.
    I emailed Probotix about the issue. They were prompt and helpful. They then shipped me a replacement board for free without me asking. Phenomenal service!
  1. Single TB6560 Drivers+Breakout board?
    By Zeppelin1007 in forum Stepper Motors / Drives
    Last Post: 04-22-2016, 07:42 AM
  2. Motors, Drivers & Breakout Board Wiring
    By OnezerO in forum Stepper Motors / Drives
    Last Post: 07-24-2014, 11:21 PM
  3. Connecting Breakout board to Stepper Drivers
    By bleker in forum Stepper Motors / Drives
    Last Post: 07-08-2014, 10:03 PM
  4. Wiring breakout board to old Isel Stepper drivers
    By TashadraCPT in forum Stepper Motors / Drives
    Last Post: 08-29-2012, 06:40 PM
  5. PROBOTIX PBX-RF Breakout Board problems
    By artwood_decor in forum Stepper Motors / Drives
    Last Post: 04-15-2008, 09:47 PM
