Originally Posted by
John S.
OK re-downloaded the program.
Went thru what GM stated above and used light as the code.
What am I looking at ?
Loaded a program and couldn't see what to do with it other than renumber it.
Tried help and found backplot, it says go to file and select backplot, but no backplot listed under files.
Found adjust spindle speed under help.
It said go to Process and select spindle speed, did that, no spindle speed listed.
Started working down help and so far every command I have selected, comments, block skip etc, etc is missing from the menu's
So unless I'm sadly mistaken it's a 45 meg version of notepad.
John S.
You will only see backplot if you use DEMO instead of LIGHT, and then you're back to a limit of 50 lines.
So you're basically giving away the full version? Just for feedback?
WoW!
I sit corrected. They're not.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
