587,925 active members*
3,364 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > fly cutting steel. chip not clearing so scratches surface when cutter rotates
Results 1 to 5 of 5
    Aug 2011
    0
    i am fly cutting some a36 steel. i am having some problems where i guess the chips are not clearing properly, perhaps stuck to the cutting tool intermittently, so it ends up scratching the surface and thus makes these random circles over my surface.
    its really annoying
    how do I fix the problem? I dont have flood coolant system. I also tried to remove less material and cut at higher rpm so it shoots the chips further when possible, but there will always be this random occurrence once in a while where the chip maybe sticks to the cutting edge, follows the rotation and cuts into the steel piece. this essentially leaves random circles on my otherwise flat surface.
    whats solution to fixing this?
    Feb 2009
    6028
    Tool tip air blow
    Jun 2011
    68
    Quote Originally Posted by underthetire View Post
    Tool tip air blow
    YEP!
    Aug 2008
    292
    finish
    Quote Originally Posted by autobot View Post
    try oil brushed on steel or use a plastic squeeze bottle or spray wd-40. you do not need much. a coating of oil can help with chips sticking to cutting edge
    Apr 2006
    3206
    Use a carbide insert, of the correct grade and geometry for the A36, and run it fast and dry with lots of air. You need to get that chip even hotter.
    Make sure cutter dia engagement isn't more than about 75% of dia, and you're climb cutting.
  1. Milling steel chip colar?
    By Rich05 in forum MetalWork Discussion
    Last Post: 07-08-2008, 07:04 PM
  2. Pluto-P servo Rotates only one way
    By JiriK in forum LinuxCNC (formerly EMC2)
    Last Post: 03-17-2008, 08:14 PM
  3. the motor rotates in jog but no in auto
    By PRIOR666 in forum Fanuc
    Last Post: 06-28-2007, 08:03 PM
  4. Chip load and cutting depth.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 07-19-2006, 08:24 PM
  5. Bad scratches Stainless Steel
    By whiteriver in forum MetalWork Discussion
    Last Post: 04-27-2004, 03:20 AM
