Hi All,
In this thread I'll gradually add all the projects I've done to my Weiss WMD25LV Machine. If you arent aware, its basically the same as the G0704, and sold under various other names with minor differences - mainly in spindle taper.
To start off with, the column support mod!
I had done this mod to a short table version of this machine, so theres a few remnants left over. The support is 200x150x10mm structural steel. It's a pain in the ass to buy short lengths. Approx weight is 35kg (machine column is only 22kg).
I wanted the holes drilled in accurate positions (previously done by hand - was a nightmare), so popped the hunk of steel on the machine:
Attachment 181104
I found you needed a way of relieving the strain of the added weight on the column (tended to pull backwards), also double as tramming aids:
Attachment 181105
Column with bolts attached:
Attachment 181106
With the column assembled. There are 2 additional supports on either side. These are mostly unnecessary, and a bit of a pain to install - they need to be welded in place while bolted (to reduce warping later).
Attachment 181107
Misc hardware. I use 2 "L" brackets to secure the column to the machine base/stand:
Attachment 181108
The receiving area. I've made a large enclosure with steel plate to bolt everything to, but you could achieve good results with a solid bench:
Attachment 181109
And installed:
Results in next post...
