587,694 active members*
3,676 visitors online*
Results 1 to 5 of 5
    Aug 2003
    318
    Flashcut Post Proccessor
    Anyone out there with a Post Proccessor for Artcam?
    Donny
    Oct 2003
    81
    The Precix (Inch) post works for me.
    Steve
    Aug 2003
    318
    I'll try it. I have used Gcode_inch_arc. It works but I think it could be more optomised. To cut a circle it takes 135 lines of code. It should not talke that much.
    Donny
    Oct 2006
    9
    Is there a four or five axis post of camworks to flashcut out there? I was told that someone in the Chicago area had one but I could never get any contact information. Please email me at [email protected]
    Jan 2007
    634
    Artcam comes with a number of default post processors, several of them being for Model Master brand mills. Since Models Master uses Flashcut controllers on their products, you can just use their postp's as a template or just modify them for your specific hardware properties.
    I actually didn't bother in one case, just set up a special profile in Mach with the data skewed to correct for the differences between my machine and the one the postp was written for. Just used the postp bone stock in that case. A real easy and transparent, if inelegant, way to do it.
  1. Emco Compact 5 PC...have ????
    By Double G in forum Mini Lathe
    Last Post: 08-23-2010, 12:26 AM
  2. Upgrading control hardware - Emco
    By eDudlik in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-08-2009, 07:52 AM
  3. Flashcut Post Processor
    By whiteriver in forum OneCNC
    Last Post: 12-16-2003, 05:04 AM
  4. Flashcut Post For Artcam
    By whiteriver in forum ArtCam Pro
    Last Post: 12-09-2003, 05:14 PM
