587,920 active members*
3,361 visitors online*
    Mar 2009
    291
    FIXTURE OFFSETS
    If i am maching one part which offset table should i be useing? Pallet offset fixture offset or nc offset?. And how do i add multi parts if i need to? And which page do i put my tool lenghts in active tool set or tool file?
    Thanks Dave,
    Apr 2004
    353
    There is a copy of the operators manual here:
    http://websystem.gismo.se/gismo/file...G%20MANUAL.pdf
    Check out chapter 4, there are some good step by steps in there to help you with you part/tool setups. At the end there is a "How Do I...." section for specific examples of some things.
    Mar 2009
    291
    Thanks laka i will read it
  1. Fixture Offsets with Tool Changes
    By HLF Ordnance in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2011, 06:29 PM
  2. Fixture offsets, X3
    By KevinV_MEI in forum Mastercam
    Last Post: 02-06-2011, 05:04 PM
  3. Z Fixture offsets
    By gbpacker in forum Fadal
    Last Post: 09-02-2009, 09:41 PM
  4. fixture offsets
    By beartrax in forum G-Code Programing
    Last Post: 11-15-2008, 01:19 AM
  5. FIXTURE OFFSETS
    By BAD DOG in forum G-Code Programing
    Last Post: 05-02-2008, 12:23 AM
