587,157 active members*
3,131 visitors online*
IndustryArena Forum > CAM Software > CamBam > First Look at CamBam's Gear Template Generator
Results 1 to 2 of 2
    Feb 2011
    0
    [ame=http://www.youtube.com/watch?v=PENds3kUy0Y]Wooden Gears and a Stepper Motor... - YouTube[/ame]
    After a year of learning GCode by hand on my zentoolworks 7x7 I have finally upgraded to CAM software (specifically CamBam). First thing to do was to use the gear generator. Here is the result. The Bottom gear has a slight wobble as it was carved using a dremel as the spindle. That was the last of that. I upgraded the spindle to a Bosch Colt for the top gears. Much better depth per pass and zero turn out!.
    The gears are run by a stepper motor which is driven by a Phidgets stepper motor controller and some custom c#.
    Feb 2005
    521
    Quote Originally Posted by skookum42 View Post
    ...First thing to do was to use the gear generator. Here is the result...
    Nice one!
    Here is something I made with the gear generator...
    [ame=http://www.youtube.com/watch?v=skwF7IdNPIw]CamBam made Klann linkage walking crab robot[/ame]
    You might also be interested in a new python script I've uploaded for animating gear drawings.
    CamBam reference library - Gear Rotation Animation
    Have fun!
    www.cambam.co.uk
  1. Bevel Gear Cutting with Involute Spur Gear cutter
    By basalt in forum MetalWork Discussion
    Last Post: 05-06-2012, 10:13 PM
  2. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  3. What size gear belts for stepper gear reducer?
    By Danno in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-28-2011, 10:28 PM
  4. Lazy Cam and Involute Gear Generator
    By John Tribe in forum Uncategorised CAM Discussion
    Last Post: 04-18-2011, 03:09 PM
  5. Wood Gear Generator?
    By Regnar in forum WoodWorking Topics
    Last Post: 07-27-2007, 04:20 AM
