587,462 active members*
3,065 visitors online*
Results 1 to 20 of 20
    Jun 2010
    46
    First half-decent machine build attempt
    Ok, first a little background. I am in college, always get started on projects over breaks, then they fade out over the semester. Anyway, a couple years back, I bought some random linear bearings and some odd assemblies on ebay and threw them together on a wooden frame just to get some satisfaction of a 'cnc machine'. It's been sitting in my basement collecting dust ever since.....
    So, this winter, I got hooked on the idea again that I am going to make a mill that might actually be able to do some work.
    Goals:
    1) Design a small machine that can mill some small aluminum parts.
    2) Use what I have previously purchased, but let a little money out so I can actually build a decent machine.
    3) Try to keep cost low.
    Well, goal 3 is going to be an issue, since I'm already over $500 and don't even have a frame built (or a head assembly), but it could be worse. I've sold some things to offset the cost, anyway.
    In the spirit of keeping things cheap, I'm using SBR16 supported shaft rails for the X/Y table motion.
    For the Z, I had 17" long 5/8 thomson shaft with 2 precision steel bearings. I cut the shaft in half, bought two more bearings and 4 pillow blocks to press the bearings into. Not sure if this is going to be too small of travel yet.... I think I can only squeeze 2.5 to maybe 3" of travel out of it (thinking off the top of my head without the shafts in front of me).
    I scored a pair of 18" big ballscrews with timing pulleys on the end off ebay for a good price, and they seem in great condition, so I will use them for the X and Y table motion.
    Here is the current lot of parts, with the Y axis semi-assembled on 1/4" 8x18" aluminum plate. The 'saddle' plate is just a 1/4" 6x8" plate right now. I will probably beef up that saddle, just trying to decide if I need different dimensions. The X will be similar, except only 6" wide if I keep the current plan. This should allow a decent work area table for small stuff.
    You can see the screw and 6x18" plate on the right. On the far left, you can kindof see a small ballscrew assembly that I might use for the Z axis, the only problem I have is that it is, I think, 1 TPI, and I am not planning on using $200 stepper motors.
    I have received the second set of linear shaft bearings, so I will just set it together later and take a pic for you to see what my plans are. Currently I just want everything together so I can see how this will work out.
    I'm having trouble designing a frame though. Really can't decide which approach to take. I was inspired by Leeway's 8020 build. Steel tubing (possibly filled with something) may be a cheaper option though. I'd like to stay away from having things welded though...
    I was also looking at the possibility of purchasing the 'solid column' replacement from LMS to use, and possibly the mini mill head assembly to bastardize and try to put a makeshift belt-drive on until I could make brackets. I'd like some thoughts/suggestions on spindle and column ideas if you have any.
    Anyway, more to come...
    Jun 2010
    46
    Mini update: Received new dial indicators and new set of linear rails. Too much other stuff to do tonight, so I will update you with more visuals tomorrow afternoon.
    Still looking for suggestions on a mill head and column. I found sherline headstocks that are cheap, but aren't they for even lighter work than the x2 spindle? Pretty sure I'll just end up with an x2 head. Anyone happen to know the dimensions of the bolt pattern on the back of the x2 spindle housing?
    Jun 2010
    46
    Ok, laid out the X axis. Will drill and bolt together tomorrow for a test. I ordered a Chinese 800w water cooled spindle to start with. Still need a vfd though... Probably will pay more for a vfd than the spindle lol.
    Pics of x/y axis attached.
    Attached Thumbnails Attached Thumbnails C360_2013-01-17-17-30-07.jpg   C360_2013-01-17-17-29-51.jpg   C360_2013-01-17-17-29-35.jpg   C360_2013-01-17-17-29-26.jpg
    Jun 2010
    46
    I've been delayed a bit with other responsibilities, and the fact that I've ordered more parts that I want to wait for. I've scored a large base with blanchard ground aluminum flat top from eBay that I will use to bolt the column to.
    I have purchased a piece of 3x6" 8020 extrusion for the column, as I've seen it work well in Leeway's build. I have also ordered 8 1/4-20 threaded rods to go through the extrusion holes into the base plate. I will probably also purchase an angle plate to square up and support the column as Leeway did. Then I can possibly fill it for additional rigidity in the future.
    I've also purchased a few pieces of aluminum plate to put together my z-axis. Currently, everything is ordered except for a VFD for the spindle. I'm thinking of going with a Teco EV series 1hp since it is affordable and can run on 110v. My panel is full and can't run another 220 line..
    Well, I'll have progress pictures sometime this weekend i'm sure.
    Looks good similar to what I have built. I used an X2 head, treadmill motor and KBMM controller.
    IMHO I would only use allen headscrews its easier to use and they tighten up well without stripping, unlike philips head screws. They are easier to remove in tighter places as well.
    Good luck with the build!
    www.VicRC.com
    Jun 2010
    46
    Thanks. Yeah, I'm going to buy some allen head screws. I have an 800W chinese spindle, but no VFD, so I might end up just getting an X2 head to start and wait for a good deal on a VFD to come along since for the price of a VFD I could almost buy the X2 head... What are the dimensions of the X2 head? I do have a treadmill motor too that I could probably do a belt drive.
    Anyway, I received everything I've currently had ordered now I think. More aluminum plate, 3x6 aluminum extrusion, and threaded rod to go through the extrusion. Here are some pics of the pieces that will become the Z assembly, the column, and overall how it will basically fit together.
    When I was putting the X axis on top of the Y I was thinking maybe it would be better to have the rails bolt to the saddle of the Y axis and have the table on the bearings on top, instead of upside down. Although I think it looks neater upside down (X axis bearing blocks bolted to saddle plate, rails upside down bolted to table). I have pics of both, What do you think?
    Attached Thumbnails Attached Thumbnails s3NZunJ.jpg   EMebtsL.jpg   WHXUrEI.jpg   AOwzuXh.jpg
    When I built mine, I opted for the first option because
    1 - you get larger table
    2 - the pillow blocks are always under the tool spindle head so its always supported
    3 - because of 2 you don't need to space the pillow blocks further apart and you will get more travel on the X.
    4 - if you went with the smaller top you will have to cover the ballscrew with some covers left and right of it.
    5 - you wont need a second aluminum plate as you can mount the pillow blocks directly on top of the Y platform ( you can use that top plate for the Z mount instead)
    I have seen many others try the smaller top option and I still dont know why.
    www.VicRC.com
    Jun 2010
    46
    Those were my thoughts as well, and probably what I will go with. I still plan on using the two 1/2 plates, that way each axis will be assembled and simply bolted together. It should allow for some adjustment/shimming if necessary to square the table up also. Unless I take a look at it again and think it will be easy to put it all on one plate and change my mind again. :P
    I'm looking more and more into using an X2 spindle assembly from littlemachineshop and running it with a treadmill motor. Any thoughts/suggestions for other cheap alternatives?
    Edit: In looking around, I'm thinking a Taig spindle would provide better precision than the X2 spindle, while still allowing tooling up to 3/8. It is also easy to mount and easy to mount a motor to. I think I can get the spindle, mount adapter, pulleys, belt, and motor mounting hardware for ~$160.
    Jun 2010
    46
    Smallish updates:
    Drilled holes in the base for the 8 threaded rods through the column. Drilled the large holes in the end plates for the Z axis assembly. Taig spindle has been ordered.
    Jun 2010
    46
    Ok, weekend again, so I might work on a few things. Yesterday I put together the motor mount for the taig spindle and an old treadmill motor. I used a thick piece of sample 'plastic lumber' that has been laying around for years and a steel angle bracket to sturdily attach it to the taig spindle. The motor had a bracket that has an adjustment for belt tightness already, so that made things easier. I tested it out and it seems to run smoothly and quietly with quite a bit of torque on the low speed pulley! Should be good to start, anyway.
    Attached Thumbnails Attached Thumbnails spindle1.jpg   mchsMlC.jpg.jpg   sVXozhZ.jpg
    Jun 2010
    46
    Another weekend, a little more progress.
    I've mostly assembled the Z-axis. Just needs a bit of tweaking and counterboring some of the holes for the screws. The rods are just a slip fit into the end plates so I put set screws in through the sides. It all feels pretty rigid.
    Attached Thumbnails Attached Thumbnails yz-front-top.jpg   yz-front-bottom.jpg   yz-side.jpg
    Jun 2010
    46
    OK. Three axis are assembled. Just need to tweak the alignment and add the table top. I already fooled with it to elongate the ballscrew nut mount holes on the X axis saddle plate, and once it was all together I cut along the back edge of the top plate. Seems to cut well (for using a used endmill and moving the axis by hand).
    Next step is to mount the motors. I already have holes drilled and tapped in the top plate for the X axis motor. Just need to drill and tap the base for the Y motor mount also. The Z, I'm not really sure how I will end up mounting that motor. I would like to do a belt drive like the other axis since the Z screw is about 1 TPI.
    Sep 2006
    6463
    Hi, I admire your "give it a go" approach, even though I have reservations aboyt some of the build.
    So without being too picky, i would strongly suggest you add another piece of material to the back of the column to make it more rigid.
    At the moment it is like a tombstone, that means it is thinner in the Y axis direction than the X axis direction and will be subject to forces from the cutter that will push it back and unable to ersist these forces.
    The moment you try drilling you will get an upward force that will lever the column away from the verticle in a backward direction.
    You would need to add another column bolted to the first and also secured to the base.
    This is a relatively simple fix, but will pay dividends when you start cutting.
    If another colum of the same section added to the back is not an option, then I would suggest adding two braces (square steel tubes) attached to the column top at either side and angle back and attached to the base like an upside down Vee.
    This will add enormous resistance to deflection, but will not add any restriction to the movement of the various slides etc.
    It's looking pretty good so far given it's humble beginnings.
    Ian.
    Jun 2010
    46
    Thanks for the reply. Yes, I completely agree that there should be more support for the column. I got the idea of using the 3x6" extrusion for the column with threaded rod through the length from Leeway's machine build. He used a large angle plate on the back of the column for support. The problem I am having is the lack of much room behind the column for a support bracket. I only have about 3 inches between the column and rear edge of the base plate. I do have a 3x3.5x4 angle plate I could use, but I don't think it will really be enough. Not sure what I will do at this point. I know the column, as is, is pretty darn rigid when those threaded rods are tensioned. My plans were to fill it with something eventually to make it more solid and dampen vibration.
    Today I added another plate on the top X axis plate which the table will be mounted to. I'll also need to add way covers, at least to cover the Y axis ballscrew and rails. Currently I've been using a piece of rubber that fits nicely over it. Might attach that somehow.
    Jun 2010
    46
    Added table and way covers today. Table is two pieces of 1x3" extrusion, making total table area of 6x16". The way covers were kindof hacked together with rubber laying around, but turned out pretty good for now. I've been thinking about how to mount the Z motor, and I'm still going back and forth between direct and belt driven. I suppose either will work. I'd like to go with a belt and reducing gearing like on the other ballscrews, but I will need to replace the flex coupling with a long rigid coupling to clear the 'stand off' that the flex coupling is in now. (and that's kindof a pain for me since i don't have a lathe). I suppose I could pull something off with the smaller couplings I have... ballscrew shaft -> coupling -> shaft to clear above -> pulley on top.
    I'll probably at least mount the X and Y motors tomorrow, and maybe even get a motion test going.
    Attached Thumbnails Attached Thumbnails rvKmlKm.jpg   PnKbCDs.jpg   haI8t0E.jpg   G3goyru.jpg
    Jun 2010
    46
    OK, basic machine is together now. I used it to manually make some modifications to the motor mounts (pics below). All motors are now mounted up. Decided to directly drive the Z axis without a belt. Tested it and the motor is able to lift the spindle without a problem.
    I need to improve the way covers eventually... still get some chips under the rear one.
    Next up is to get the wiring in some reasonable harness.
    Attached Thumbnails Attached Thumbnails ExOg6bh.jpg   mchGJMX.jpg   uz7uiB8.jpg   m7Z5KrH.jpg
    Jun 2010
    46
    Wired up the motors. Gave all axis a little test drive. Everything works great so far!
    The only motor that moves is the X axis motor, so that makes the wiring pretty easy not having to worry about cable length. All the motor wiring goes to the left side of the machine, and I left enough cable to take everything to the back which is where I will probably mount the motor driver and power supply.
    Things to do: Add limit switches, Reinforce column (fill/brace), and fix the Z axis and spindle mounting plate (it's currently OK, but needs to be beefed up).
    As it sits right now, I should be able to make some light test cuts soon under CNC.
    In the front view pic, the potentiometer knob on the left is the spindle motor speed control. Need to make it prettier eventually.
    Jun 2010
    46
    Small updates... I have one limit switch per axis wired up now in a way that will just have to do for now, haha. Test milled a small .100 radius circle under CNC so far as a quick test. Hopefully I'll have some small parts and maybe a video to show you soon.
    Jun 2010
    46
    Here are a few pics of an attempt at milling a limit switch mount out of some piece of trash composite material. Didn't work well at all since it decided to melt and rip. There were supposed to be two posts that the limit switch would snugly fit onto, but they just ended up ripping off. You can kindof see where they were supposed to be. Also, the overshot toolpaths is because I was using a facing toolpath (assuming the stock was already cut square to size).
    Anyway, I'd like to try to make one out of aluminum if I can find a piece big enough laying around.
    Failed experiment, oh well. Was nice to see it run a full program though.
    Jun 2010
    46
    Some updates for you all. The mill has been working alright. My Z axis needed a little improvement on the mounting plate, so I worked on that over the course of a few days and it turned out well. It was previously that extra piece of 1/4" aluminum with the ball nut held in position by 'sandwiching' between the bearing blocks. The bearing blocks were mounted with just screws and nuts.
    So, I got a 6x6" piece of 1/2" thick aluminum for a new nicer mount plate. I tapped the bearing pillow blocks 1/4-20, drilled the plate and countersunk the holes so the screws would be flush and not interfere with the spindle mounting. I fashioned a ballnut mount and kept it thin to minimize the space it would take up between the upper and lower bearing blocks so I could maximize travel. I also cut the extra crap off the ballscrew mount on the top and got a new flex coupling so it looks nicer.
    Note: The two empty holes above the spindle dovetail mount do not have screws in because my 1" screws were too long and hit the ballnut. If I find some shorter ones laying around I'll put 'em in, but it is alright for now.
    Attached Thumbnails Attached Thumbnails jGOar4X.jpg   ZHA8wTf.jpg   XIhxoLe.jpg   rhCOiKP.jpg
  1. Help me find a cheap but decent laser cutting machine please
    By Izzy07 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-07-2012, 08:58 AM
  2. 1st build 2nd attempt at a CNC router
    By rpe in forum DIY CNC Router Table Machines
    Last Post: 01-20-2012, 09:47 PM
  3. Build Inexpensive CNC with decent tolerances-Share your input
    By Andy990 in forum DIY CNC Router Table Machines
    Last Post: 12-26-2009, 05:49 AM
  4. Looking for a good source for decent quality machine tools
    By macdarren in forum Taig Mills / Lathes
    Last Post: 03-11-2009, 02:14 AM
  5. my first attempt at a cnc machine
    By bows0006 in forum DIY CNC Router Table Machines
    Last Post: 08-19-2007, 07:54 PM
