Originally Posted by
keen
Hi Sniper. I have been meaning to make a thicker draw bar spanner with a copper plate screwed on to save burring the top. I like your shape - could you post your G code ? - and how tight do you lock the draw bar?
here is the code for the wrench i made. i used sheetcam to create the code. i am still learning machining so the lead in and out may not be what you are used to. the inside of the wrench ended up being slightly undersized. i just touched it up on the disc sander and have not looked into why it ended up undersized. i am not sure if i made a mistake with my drawing or if something happened with sheetcam.
i believe i used 4 or 5 passes at .08" deep and .005" oversized and one pass at .385" deep (.01" through the part) with no oversize. i used a .25, 4 flute hss endmill. the engraving is not in this code. if this doesn't look right to you i can get you the dxf for it and you can change it if you like.
i tighten my draw bar tight now after having a tool holder pull out and down into the part wrecking it.
Code:
N0000 (Filename: wrench 2 [10 degree angle].tap)
N0010 (Post processor: Mach2.post)
N0020 (Date: 5/10/2008)
N0030 G20 (Units: Inches)
N0040 G40 G90
N0050 F1
N0060 (Part: wrench 2 [10 degree angle])
N0070 (Process: Outside offset 2, 1/4" endmill, 0.365 inch Deep)
N0080 (1/4" endmill)
N0090 T12 M06 G43 H12
N0100 M08 (Flood coolant on)
N0110 M03 S2140
N0120 G00 Z0.1000
N0130 X2.5616 Y0.8300
N0140 Z0.0197
N0150 G01 Z0.0000 F3
N0160 G03 X2.5212 Y0.7619 Z-0.0800 I0.1131 J-0.1131
N0170 G02 X2.5616 Y0.8300 I0.1535 J-0.0450 F8.56
N0180 G03 X2.5616 Y0.6037 I0.1131 J-0.1131
N0190 G01 X2.9738 Y0.1915
N0200 G02 X3.0191 Y0.0225 I-0.1237 J-0.1237
N0210 G01 X3.0062 Y-0.0258
N0220 G02 X2.7918 Y-0.1495 I-0.1690 J0.0453
N0230 G01 X2.3309 Y-0.0260
N0240 G03 X2.2882 Y-0.1854 I0.3575 J-0.1812
N0250 G01 X2.7491 Y-0.3089
N0260 G02 X2.8729 Y-0.5233 I-0.0453 J-0.1690
N0270 G01 X2.8599 Y-0.5716
N0280 G02 X2.7362 Y-0.6953 I-0.1690 J0.0453
N0290 G01 X2.1731 Y-0.8462
N0300 G02 X1.9531 Y-0.8462 I-0.1100 J0.4105
N0310 G01 X1.7172 Y-0.7830
N0320 G02 X1.5733 Y-0.6729 I0.0615 J0.2294
N0330 G01 X1.5675 Y-0.6630
N0340 G02 X1.5671 Y-0.6623 I0.1512 J0.0882
N0350 G03 X1.3140 Y-0.5011 I-0.2815 J-0.1625
N0360 G01 X-2.5572 Y-0.1624
N0370 G02 X-2.4679 Y0.8587 I0.0447 J0.5105
N0380 G01 X1.4294 Y0.5177
N0390 G03 X1.6202 Y0.5600 I0.0283 J0.3238
N0400 G01 X1.8876 Y0.7144
N0410 G02 X2.2101 Y0.7569 I0.2125 J-0.3681
N0420 G01 X2.3711 Y0.7137
N0430 G02 X2.5616 Y0.6037 I-0.1100 J-0.4105
N0440 G03 X2.7879 Y0.6037 I0.1131 J0.1131
N0450 G00 Z0.1000
N0460 X2.5616 Y0.8300
N0470 Z-0.0603
N0480 G01 Z-0.0800 F3
N0490 G03 X2.5212 Y0.7619 Z-0.1600 I0.1131 J-0.1131
N0500 G02 X2.5616 Y0.8300 I0.1535 J-0.0450 F8.56
N0510 G03 X2.5616 Y0.6037 I0.1131 J-0.1131
N0520 G01 X2.9738 Y0.1915
N0530 G02 X3.0191 Y0.0225 I-0.1237 J-0.1237
N0540 G01 X3.0062 Y-0.0258
N0550 G02 X2.7918 Y-0.1495 I-0.1690 J0.0453
N0560 G01 X2.3309 Y-0.0260
N0570 G03 X2.2882 Y-0.1854 I0.3575 J-0.1812
N0580 G01 X2.7491 Y-0.3089
N0590 G02 X2.8729 Y-0.5233 I-0.0453 J-0.1690
N0600 G01 X2.8599 Y-0.5716
N0610 G02 X2.7362 Y-0.6953 I-0.1690 J0.0453
N0620 G01 X2.1731 Y-0.8462
N0630 G02 X1.9531 Y-0.8462 I-0.1100 J0.4105
N0640 G01 X1.7172 Y-0.7830
N0650 G02 X1.5733 Y-0.6729 I0.0615 J0.2294
N0660 G01 X1.5675 Y-0.6630
N0670 G02 X1.5671 Y-0.6623 I0.1512 J0.0882
N0680 G03 X1.3140 Y-0.5011 I-0.2815 J-0.1625
N0690 G01 X-2.5572 Y-0.1624
N0700 G02 X-2.4679 Y0.8587 I0.0447 J0.5105
N0710 G01 X1.4294 Y0.5177
N0720 G03 X1.6202 Y0.5600 I0.0283 J0.3238
N0730 G01 X1.8876 Y0.7144
N0740 G02 X2.2101 Y0.7569 I0.2125 J-0.3681
N0750 G01 X2.3711 Y0.7137
N0760 G02 X2.5616 Y0.6037 I-0.1100 J-0.4105
N0770 G03 X2.7879 Y0.6037 I0.1131 J0.1131
N0780 G00 Z0.1000
N0790 X2.5616 Y0.8300
N0800 Z-0.1403
N0810 G01 Z-0.1600 F3
N0820 G03 X2.5212 Y0.7619 Z-0.2400 I0.1131 J-0.1131
N0830 G02 X2.5616 Y0.8300 I0.1535 J-0.0450 F8.56
N0840 G03 X2.5616 Y0.6037 I0.1131 J-0.1131
N0850 G01 X2.9738 Y0.1915
N0860 G02 X3.0191 Y0.0225 I-0.1237 J-0.1237
N0870 G01 X3.0062 Y-0.0258
N0880 G02 X2.7918 Y-0.1495 I-0.1690 J0.0453
N0890 G01 X2.3309 Y-0.0260
N0900 G03 X2.2882 Y-0.1854 I0.3575 J-0.1812
N0910 G01 X2.7491 Y-0.3089
N0920 G02 X2.8729 Y-0.5233 I-0.0453 J-0.1690
N0930 G01 X2.8599 Y-0.5716
N0940 G02 X2.7362 Y-0.6953 I-0.1690 J0.0453
N0950 G01 X2.1731 Y-0.8462
N0960 G02 X1.9531 Y-0.8462 I-0.1100 J0.4105
N0970 G01 X1.7172 Y-0.7830
N0980 G02 X1.5733 Y-0.6729 I0.0615 J0.2294
N0990 G01 X1.5675 Y-0.6630
N1000 G02 X1.5671 Y-0.6623 I0.1512 J0.0882
N1010 G03 X1.3140 Y-0.5011 I-0.2815 J-0.1625
N1020 G01 X-2.5572 Y-0.1624
N1030 G02 X-2.4679 Y0.8587 I0.0447 J0.5105
N1040 G01 X1.4294 Y0.5177
N1050 G03 X1.6202 Y0.5600 I0.0283 J0.3238
N1060 G01 X1.8876 Y0.7144
N1070 G02 X2.2101 Y0.7569 I0.2125 J-0.3681
N1080 G01 X2.3711 Y0.7137
N1090 G02 X2.5616 Y0.6037 I-0.1100 J-0.4105
N1100 G03 X2.7879 Y0.6037 I0.1131 J0.1131
N1110 G00 Z0.1000
N1120 X2.5616 Y0.8300
N1130 Z-0.2203
N1140 G01 Z-0.2400 F3
N1150 G03 X2.5212 Y0.7619 Z-0.3200 I0.1131 J-0.1131
N1160 G02 X2.5616 Y0.8300 I0.1535 J-0.0450 F8.56
N1170 G03 X2.5616 Y0.6037 I0.1131 J-0.1131
N1180 G01 X2.9738 Y0.1915
N1190 G02 X3.0191 Y0.0225 I-0.1237 J-0.1237
N1200 G01 X3.0062 Y-0.0258
N1210 G02 X2.7918 Y-0.1495 I-0.1690 J0.0453
N1220 G01 X2.3309 Y-0.0260
N1230 G03 X2.2882 Y-0.1854 I0.3575 J-0.1812
N1240 G01 X2.7491 Y-0.3089
N1250 G02 X2.8729 Y-0.5233 I-0.0453 J-0.1690
N1260 G01 X2.8599 Y-0.5716
N1270 G02 X2.7362 Y-0.6953 I-0.1690 J0.0453
N1280 G01 X2.1731 Y-0.8462
N1290 G02 X1.9531 Y-0.8462 I-0.1100 J0.4105
N1300 G01 X1.7172 Y-0.7830
N1310 G02 X1.5733 Y-0.6729 I0.0615 J0.2294
N1320 G01 X1.5675 Y-0.6630
N1330 G02 X1.5671 Y-0.6623 I0.1512 J0.0882
N1340 G03 X1.3140 Y-0.5011 I-0.2815 J-0.1625
N1350 G01 X-2.5572 Y-0.1624
N1360 G02 X-2.4679 Y0.8587 I0.0447 J0.5105
N1370 G01 X1.4294 Y0.5177
N1380 G03 X1.6202 Y0.5600 I0.0283 J0.3238
N1390 G01 X1.8876 Y0.7144
N1400 G02 X2.2101 Y0.7569 I0.2125 J-0.3681
N1410 G01 X2.3711 Y0.7137
N1420 G02 X2.5616 Y0.6037 I-0.1100 J-0.4105
N1430 G03 X2.7879 Y0.6037 I0.1131 J0.1131
N1440 G00 Z0.1000
N1450 X2.5616 Y0.8300
N1460 Z-0.3003
N1470 G01 Z-0.3200 F3
N1480 G03 X2.5346 Y0.7942 Z-0.3650 I0.1131 J-0.1131
N1490 X2.5616 Y0.6037 I0.1401 J-0.0773 F8.56
N1500 G01 X2.9738 Y0.1915
N1510 G02 X3.0191 Y0.0225 I-0.1237 J-0.1237
N1520 G01 X3.0062 Y-0.0258
N1530 G02 X2.7918 Y-0.1495 I-0.1690 J0.0453
N1540 G01 X2.3309 Y-0.0260
N1550 G03 X2.2882 Y-0.1854 I0.3575 J-0.1812
N1560 G01 X2.7491 Y-0.3089
N1570 G02 X2.8729 Y-0.5233 I-0.0453 J-0.1690
N1580 G01 X2.8599 Y-0.5716
N1590 G02 X2.7362 Y-0.6953 I-0.1690 J0.0453
N1600 G01 X2.1731 Y-0.8462
N1610 G02 X1.9531 Y-0.8462 I-0.1100 J0.4105
N1620 G01 X1.7172 Y-0.7830
N1630 G02 X1.5733 Y-0.6729 I0.0615 J0.2294
N1640 G01 X1.5675 Y-0.6630
N1650 G02 X1.5671 Y-0.6623 I0.1512 J0.0882
N1660 G03 X1.3140 Y-0.5011 I-0.2815 J-0.1625
N1670 G01 X-2.5572 Y-0.1624
N1680 G02 X-2.4679 Y0.8587 I0.0447 J0.5105
N1690 G01 X1.4294 Y0.5177
N1700 G03 X1.6202 Y0.5600 I0.0283 J0.3238
N1710 G01 X1.8876 Y0.7144
N1720 G02 X2.2101 Y0.7569 I0.2125 J-0.3681
N1730 G01 X2.3711 Y0.7137
N1740 G02 X2.5616 Y0.6037 I-0.1100 J-0.4105
N1750 G03 X2.7879 Y0.6037 I0.1131 J0.1131
N1760 G00 Z0.1000
N1770 (Process: Outside offset 2, 1/4" endmill, 0.385 inch Deep)
N1780 X2.5262 Y0.7946
N1790 Z0.0197
N1800 G01 Z0.0000 F3
N1810 G03 X2.5262 Y0.5684 Z-0.2513 I0.1131 J-0.1131
N1820 G01 X2.6208 Y0.4738 Z-0.3850
N1830 X2.5262 Y0.5684 F8.56
N1840 G02 X2.5262 Y0.7946 I0.1131 J0.1131
N1850 G03 X2.5262 Y0.5684 I0.1131 J-0.1131
N1860 G01 X2.9384 Y0.1562
N1870 G02 X2.9708 Y0.0354 I-0.0884 J-0.0884
N1880 G01 X2.9579 Y-0.0129
N1890 G02 X2.8048 Y-0.1013 I-0.1207 J0.0324
N1900 G01 X2.3065 Y0.0323
N1910 G03 X2.2379 Y-0.2237 I0.3819 J-0.2395
N1920 G01 X2.7362 Y-0.3572
N1930 G02 X2.8246 Y-0.5103 I-0.0324 J-0.1207
N1940 G01 X2.8116 Y-0.5586
N1950 G02 X2.7232 Y-0.6470 I-0.1207 J0.0324
N1960 G01 X2.1602 Y-0.7979
N1970 G02 X1.9661 Y-0.7979 I-0.0971 J0.3622
N1980 G01 X1.7301 Y-0.7347
N1990 G02 X1.6165 Y-0.6477 I0.0485 J0.1811
N2000 G01 X1.6107 Y-0.6378
N2010 G02 X1.6104 Y-0.6373 I0.1080 J0.0630
N2020 G03 X1.3184 Y-0.4513 I-0.3248 J-0.1875
N2030 G01 X-2.5529 Y-0.1126
N2040 G02 X-2.4722 Y0.8089 I0.0403 J0.4607
N2050 G01 X1.4250 Y0.4679
N2060 G03 X1.6452 Y0.5167 I0.0327 J0.3736
N2070 G01 X1.9126 Y0.6711
N2080 G02 X2.1972 Y0.7086 I0.1875 J-0.3248
N2090 G01 X2.3581 Y0.6654
N2100 G02 X2.5262 Y0.5684 I-0.0971 J-0.3622
N2110 G03 X2.7525 Y0.5684 I0.1131 J0.1131
N2120 G00 Z0.1000
N2130 M09 (Coolant off)
N2140 M05
N2150 M05 M30
