MR-J2 is only if you have Fusion or newer control. If your machine is a M+ control, you don't have any J2 drives.
A few other things to note.... you may not need to set a new 'zero' for this. But, in order to clamp/unclamp the table, you need to be @ the Home 2 position in Z (you'll want to be there anyway). You'll also likely need to use the MF1 key to hold down at the same time while using the Maintenance side of the control. Many of the M+ controlled FH machines also had a "Zero" or Home key on the maintenance side for the tool changer(magazine) and the pallet changer. Simialar to homing out a machine when you first turn it on (unless you have absolute position detector).
It's just a part..... cutter still goes round and round....
