587,421 active members*
3,354 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Feed Rate wrong in G-code Randomly
Results 1 to 5 of 5
    Jan 2007
    209
    I'm doing a roughing routine with multiple passes and multiple ramps into the material.
    Some passes the Gcode is correct with a slow feed rate of 10ipm for the approach and then 150ipm for the cut. Other passes I see the 10ipm for approach but not 150ipm for the cutting. It appears totally random of when it is incorrect.
    I'm running. 5.0.2014.610
    Here's an example of good code:
    G01 Z0.75000 F10
    X0.07778 Y4.41123 Z0.74746 F150
    Here's the bad code a few passes later:
    G01 Z0.75000 F10
    X0.03333 Y5.43146 Z0.74455
    It's missing the F150. Happens 1 to 2 times in the code on a 45min. job.
    Edit: Forgot some important info: I'm using the EMC Post processor.
    Andrew
    Apr 2003
    1357
    Re: Feed Rate wrong in G-code Randomly
    Is it the default EMC Post processor or has it been edited?
    Mar 2004
    1661
    EMC? The EMC processor is obsolete. You should test the post called LinuxCNC.
    Sep 2006
    247
    For what it's worth, I get this exact same error and I'm applying the Mach3 post processor.
    It has always happened that the "Z" federate is set, but the "X,Y" feedrate is missed occasionally and seemingly randomly. It has never damaged a part because Z is almost always much lower rate.
    Still, it is very annoying.
    I am using very old versions, so I never thought to mention it on this site before. (Rhino 3, madCam 2).
    Mar 2004
    1661
    You might need to change the post processor to set the speed at every line. Make a copy of the post file and edit, it is totally safe as long as you make new copies of the file,
  1. X axis randomly tracks wrong way
    By Shadowfax in forum Chinese Machines
    Last Post: 01-23-2013, 06:38 PM
  2. Problem setting Feed rate w G-code
    By mlind in forum G-Code Programing
    Last Post: 07-26-2011, 08:05 AM
  3. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  4. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  5. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
