587,735 active members*
3,463 visitors online*
Thread: Feed Hold
Results 1 to 11 of 11
    Feed Hold
    Is there a G Code or other command that can be written into a program to pause the program at a given point until the cycle start is pressed?
    Thanks in advance for any help or suggestions.
    John
    Jun 2006
    7
    m0= program stop
    Help
    Jeff,
    Thanks for the help.
    John
    Jul 2005
    12177
    Be careful using M00 and M01. Both of these will stop the spindle and it will not restart when Cycle Start is pushed, but the feed will start and try to push a stationary tool through the part. You need a M03(4) after the program stop.
    Dec 2003
    24220
    Quote Originally Posted by Geof View Post
    This would be done on most systems at the discretion of the MTB, as the spindle and M codes are written in the ladder.
    I have often seen these and other eventuality's not foreseen by the PMC writer.
    Al.
    Albert E.
    Help
    Hi Geof,
    Thanks for the information and words of caution. I read the HAAS manual on the M codes.
    Here is what was printed:
    The MOO code is used to stop a program. It stops the axes, spindle, turns off the coolant (including through spindle coolant). The next block (block after the MOO) will be highlighted when viewed in the program editor. Pressing Cycle Start will continue program operation from the highlighted block.
    Too bad they didn't put your words of warning in the manual as a (note) as they do on other M Code commands.
    Thanks again, from both me and my cutting tool.
    John
    Dec 2003
    24220
    Quote Originally Posted by HelicopterJohn View Post
    To me, that is a glaring oversight on the part of the MTB, I would think it is a given that if you 'Push Cycle Start' to continue the program, you obviously need the spindle on !
    Al.
    Albert E.
    Help
    Hi Al,
    Maybe someone from HAAS is monitoring this forum and will pass this on the the guy that writes the technical manuals.
    I am a newbie here and there is a lot I need to learn. Thanks to you guys for helping me along the way.
    P.S. What is MTB? Manual Technical Book?????
    What is PMC as it pertains to the PMC writer?
    What is a ladder as it pertains to this operation? Is it like a sequence of events that happen during a particular operation?
    Sorry for all the questions just trying to understand all this a little better.
    John
    Dec 2003
    24220
    MTB Machine Tool Builder, in this case HAAS.
    PMC is Programable Machine Controller, it is the side of the control that performs the M,S,T codes and misc functions and is configured by the MTB as to how it actually does the task.
    The ladder describes the format of the PMC, it is represented and programmed in a ladder type logic format.
    Al.
    Albert E.
    Help
    Hi Al,
    Thanks for taking the time to educate an Newbie.
    John
    Dec 2006
    447
    John,
    Give me a call, your CAM software in conjunction with the Haas control can handle this nicely.
    Vern
  1. Feed hold problem
    By kirby in forum Fanuc
    Last Post: 07-13-2007, 02:33 PM
  2. Stop or Feed Hold Key
    By rweatherly in forum Mach Mill
    Last Post: 11-12-2006, 08:28 PM
  3. Axis move during feed hold
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-12-2006, 04:12 PM
  4. Door Feed Hold
    Last Post: 09-12-2006, 03:45 PM
  5. What should Feed Hold actually be??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 01-22-2006, 07:04 PM
