587,487 active members*
3,208 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Faulty arc outputs
Results 1 to 4 of 4
    Dec 2004
    185
    Faulty arc outputs
    I am stuck with a particular problem regarding the way Mastercam posts my arc moves. I suspect that the problem must lie with either the machine/ control definition, or with the post itself. I have been using the system for a long time now and can not understand why it is only doing this now....
    Problem: When cutting 2d contours, the nc file would contain G2 and G3 commands that also have a very small z move included. The parts i am cutting now was drawn up by myself in Acad and pulled into McamX3. I m sure there is no Z component in the arcs themselves. Can someone please point me in the right direction for where to start looking? at present i just delete the Z component from the command by hand, but this takes time and there is the risk of getting it wrong...
    this is what the code looks like:
    G37 J1
    G90 G71 G0 T0 Z0.
    X-40. Y0.
    S2000 M42
    T01 F600
    M3
    M07
    X-14. Y-6.5 Z3.
    Z2.
    G1 Z-9.167 F250
    G1 X0. F600
    G1 X44.474
    G1 X63.087 Y4.909
    G2 X90. Y12.502 Z-9.165 I90. J-39.
    G2 X141.502 Y-39. I90. J-39.
    G2 X90. Y-90.502 I90. J-39.
    G2 X63.085 Y-82.91 I90. J-39.
    G1 X44.474 Y-71.5 Z-9.167
    G1 X0.
    G2 X-12.5 Y-59. Z-9.165 I0. J-59.
    G1 Y-19. Z-9.167
    G2 X0. Y-6.5 Z-9.165 I0. J-19.
    G1 X-14. Y-11.5 Z-9.167
    G1 X0.
    G1 X45.602
    G3 X46.125 Y-11.355 Z-9.165 I45.6 J-10.5
    G1 X65.7 Y0.646 Z-9.167
    G2 X90. Y7.5 Z-9.165 I90. J-39.
    G2 X136.5 Y-39. I90. J-39.
    G2 X90. Y-85.5 I90. J-39.
    G2 X65.7 Y-78.645 I90. J-39.
    G1 X46.125 Y-66.647 Z-9.167
    G3 X45.6 Y-66.5 Z-9.165 I45.6 J-67.5
    G1 X0. Z-9.167
    G2 X-7.5 Y-59. Z-9.165 I0. J-59.
    G1 Y-19. Z-9.167
    G2 X0. Y-11.5 Z-9.165 I0. J-19.
    G1 X-14. Y-6.5 Z-9.167
    G1 Z-18.333 F250
    Apr 2006
    125
    Possibly a rounding issue - look at the format statement in the post?
    Dec 2008
    3126
    What control & what post are you using ?
    It doesn't look like a "normal" output,
    ---- G-codes not normally stated on each line, as they are "modal"
    ---- decimal points missing on feedrates
    What happens if you use the same geometry, but drawn within Mastercam ?
    - it could be an Acad glitch
    what is set in the toolpath operation parameters regarding :-
    -- cut parameters ( clearance, retract, top of stock, depth )
    -- what cut-type ( 2d or 3D contour, ramp etc)
    -- lead in/out ( **** you may have a ramp value set *** )
    -- multi-passes
    -- cut depths
    ( put up pics of each of these pages )
    Dec 2004
    185
    The Control is a Anilam GXM (Crusader) from circa 1987~
    I am using a post that was converted from Mastercam 9. The post was working fine in 9 and I am sure it never gave problems in X3....something must have changed.
    I will check if the geometry is created in MC
    The op in question did use depth cuts and multi passes, but no ramp was selected (2d contouring) i will check all the details again and post the screenshots if drawing in MC does not solve.
    Thank you for taking the time to help.
    P
  1. Best fix for a faulty Sieg SX3 way?
    By Chilli in forum Benchtop Machines
    Last Post: 06-24-2010, 09:45 AM
  2. SX3 E-Stop Faulty
    By SDesigns in forum Syil Products
    Last Post: 07-06-2009, 03:35 AM
  3. Faulty lasertube?
    By Skibbe10 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-01-2009, 08:09 PM
  4. Tnc 151 Vdu Faulty?
    By PRIOR666 in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2007, 03:54 PM
  5. Faulty stepper?
    By kong in forum DIY CNC Router Table Machines
    Last Post: 05-26-2003, 03:15 PM
