587,133 active members*
3,164 visitors online*
Results 1 to 4 of 4
    Nov 2017
    1
    Fanuc VB.NET app
    Hello,
    I am trying to build a vb.net based application, that allows me to send and retrieve programs from the machine.
    When I try to alloccate the library I get the error "System.AccessViolationException". Can check the code on the attached image.
    Does anyone knows why this happens?
    Best regards
    Apr 2005
    3634
    Re: Fanuc VB.NET app
    Maybe this webpage will help, specifically the 2nd solution at the bottom of the page that mentions the Fanuc 64-bit DLL If you're on a 64-bit PC.
    Free DXF - vectorink.com
    Jan 2022
    6
    This is often an indication that another memory is corrupt.YoWhatsApp APK Download
    Aug 2023
    1
    Post Re: Fanuc VB.NET app
    The System.AccessViolationException error occurs when you try to access memory that is not allocated or that you do not have permission to access. In your code, you are trying to allocate a library using the statement: try below solution and share with me on tm
    Dim lib As New Marshal.LoadLibrary(dllPath)
    However, the dllPath variable is not initialized, so it is not pointing to a valid file. This is why you are getting the error.
    To fix this error, you need to initialize the dllPath variable to the path of the library file that you want to load. For example:
    Dim dllPath As String = "C:\MyLibrary.dll"
    Once the dllPath variable is initialized, the code should be able to allocate the library without any errors.
    Here are some other possible reasons why you might be getting the System.AccessViolationException error:
    You are trying to access a memory address that is outside of the bounds of the allocated memory.
    You are trying to write to a memory address that is read-only.
    You are trying to access a memory address that is already in use by another process.
    If you are still getting the error after fixing the above mentioned issues, you can try the following:
    Use a debugger to step through the code and see where the error is occurring.
    Check the documentation for the library that you are trying to load to make sure that you are using it correctly.
    Contact the library's author for help.
