587,316 active members*
3,327 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc SV117 Current Conversion error
Results 1 to 4 of 4
    Sep 2013
    8
    I have a Fanuc A06B-6079-H106 servo amplifier that gives SV117 Current Conversion error immediately on power-up.
    Has anyone seen this error before? I have been an electronic tech for about 30 years but have just entered the CNC world as a controls tech.
    I am thinking maybe an A/D convertor failure but not sure. I would also like to set up some kind of test station so I can test Fanuc servo amplifiers. Does anyone have any ideal's or suggestions?
    Aug 2007
    793
    what is control series?
    what drive shows?
    did you swap cables with another drive?
    Sep 2013
    8
    Yeah, I troubleshot down to the servo amp and replaced it. I want to repair the faulty drive if possible. When I get a chance, I will swap out the control board (in the drive) with the control board in the replacement drive. Where I work, there is no way of testing so I have to wait until a machine is down to perform the swap.
    Aug 2007
    793
    I know how the currnent is detected in servo amps of previous models A06B-6066, but most likely the same is in your amp
    there are just shunts and analogue galvanic isolator
    if you want you could PM me and I tell you which elements may be "bad guys"
  1. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
  2. Error Code 32 (over current) at start up
    By GEC-ENG in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-17-2011, 01:54 PM
  3. Fanuc 5t over current field light on
    By nickster in forum Uncategorised MetalWorking Machines
    Last Post: 01-11-2011, 07:00 AM
  4. Current Best X2 CNC Conversion Kit
    By Steoh in forum Benchtop Machines
    Last Post: 12-30-2010, 12:30 PM
  5. Replies: 2
    Last Post: 04-19-2007, 03:37 AM
