587,801 active members*
3,476 visitors online*
Results 1 to 8 of 8
    fanuc series 15ma
    How do I reinstall parameters?
    Had Ram Parity error. Entered parameters by hand but unable to enter 9100-9147. Even with the 2021(memory, could be wrong) set to 0. Says they are locked.
    What Software do I use via CPU?
    My machine is a Kao Ming KMC-3000s
    I have Cimco Editor. Can I use this?
    Also I have parameters in the 10000 group on my backup list, No idea what these are for and I don't have any PMC data(Timers, Counters, Keep relays etc....)
    So am I screwed?
    Please Help!!
    May 2013
    128
    you have to enter the parameters from IPL Mode the 9000 Series rest after in normal mode
    Aug 2007
    793
    In response to your message: I actually tried that, the problem is I have parameters 9000, 9001, 9002, 9020 and then it starts at 9100. So if I start entering the 9100 parameters after the axis option(9000) everything is all wrong because I would have skipped those other 3 parameters. Do you know what to do about that?
    Aug 2007
    793
    if series 15 like 10, 11, 12 (I think it is so), first of all you have to enter to IPL mode through keeping "." and "-" depressed while power your CNC on
    then enter number of axes (this parameter then will appear as 9000 in normal state) and after that get started to enter options
    option 1 is 9100, option 2 is 9101 and so on. but you must enter them in HEX
    parameters 9001, 9002 will be set automaticaly and you will see them in normal mode (not IPL), 9100... you also will see in BIN representation, not in HEX
    about the 9020 I don't know but suspect it will be set automaticaly also
    Ok, I will try that.
    What about the PMC data? Am I wasting my time since I do not have that information?
    Time I'm afraid is my most precious commodity!
    Apr 2009
    1379
    Call me at 289 389 6117 and I will guide you through that.
    Bill
    I have followed a procedure in an attempt to enable helical interpolation on our Fanuc 15M controller for our MV-65 mill. I followed the procedure of holding the 7 and 6 while powering on and entering the IPL mode. Once I updated all the option values though, the parameter 9020 did not return to its value that it was before the update. Now the machine is erroring out on start-up. I am getting Errors SV026 and SV027 and the machine will not proceed any further. Any help would be greatly appreciated to get me back up and running.
  1. fanuc series 15ma
    By Precision_JC in forum Servo Motors / Drives
    Last Post: 10-29-2013, 04:35 PM
  2. G43.2 on Fanuc 15MA
    By SES1 in forum Fanuc
    Last Post: 05-11-2013, 08:42 PM
  3. NCT TMC V40 with FANUC 15MA
    By zavateandu in forum Fanuc
    Last Post: 02-10-2011, 09:50 AM
  4. Fanuc 15MA 4 place decimals
    By Rick_EE in forum Fanuc
    Last Post: 02-03-2011, 06:59 PM
  5. Fanuc 15MA Time
    By utengineer04 in forum Fanuc
    Last Post: 06-09-2005, 08:14 PM
