Friends,
Is It Possible To Display The Ladder Logic In The Crt In Fanuc OTA Controller Like OMC Controller. .If So What Is The Parameter To Be Set.The Machine Is 1985 Model.
Thanks,
Chandru
Friends,
Thanks,
Chandru
Chandru....IIRC the model C is the only one that you can display the ladder on. A and B can not display the ladder.
Stevo
THANKS A LOT MR.STEVO FOR SUCH A WONDERFUL PIECE OF INFORMATION.
THANKS AND REGARDS,
CHANDRU
Chandru...you are welcome.
I was giving you some grief in some other forums about double posting on this topic
Stevo
DEAR STEVO,
PL SORRY FOR POSTING THE SAME TOPIC IN DIFFERENT FORUMS.
ACTUALLY THE MACHINE WE ARE HAVING IS A USED INE ECOSTAR (MAKE 1985)WITH FANUC OTA CONTROLLER AND THE MACHINE HAS COME WITHOUT DRAWINGS/PARAMETER BACKUP.WITH GATHERING INFORMATION HERE AND THERE WE COULD ABLE TO SWITCH ON THE MACHINE AND NOW THE DGN PARAMETERS LIKE TIMERS/COUNTERS HAVE TO BE ADJUSTED.
OUT OF URGENCY AND IN SEARCH OF SOME SOLUTION I HAVE REPEATED THE SAME TOPIC.
THANKS AND REGARDS,
CHANDRU
I can print ladder from PMC ROM, If you need please PM or email to [email protected]
Chandru,
No worries you don't need to apologize . I thought it was rather funny when i was running forum to forum and you kept popping up. I was just busting your(nuts)a bit. I know exactly what it is like to need a suggetion ASAP and have also posted across more then 1 forum. I just don't think i did that many
Glad to see you have the machine up.
Stevo
