587,762 active members*
3,460 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Fanuc OT communication problem
Results 1 to 5 of 5
    Sep 2006
    7
    I have a Fanuc OT control on a lathe,I am having a problem with the communication..I can send the programs fine but when I try to recieve .It blinks "LSK".
    The computer thinks that it has taken it fine,but the machine did not take the program..
    Any help would be greatly appreciated.......
    Mar 2007
    215
    This may sound like a dumb question but have you ever successfully sent a program on that control before?
    Sep 2006
    7
    Yes,I was sending fine a few days ago.
    Jan 2007
    333
    "LSK" means the comport is open and waiting on a program. The program must contain a % (percent) sign at the beginning followed in the next line by the four digit program number, preceeded with either a letter "O" or a ":" (colon) depending on a parameter. Try sending a program to the PC and then sending it back to the Fanuc unchanged. What software are you using on the PC?
    Sep 2006
    7
    Thanks,it sends fine,it is just recieving it that is the problem..the machine output might be bad on the machine..I am having it check out..thanks again.
  1. Fanuc O-M g41 g42 problems
    By sgrove in forum Fanuc
    Last Post: 04-21-2007, 08:16 PM
  2. Fanuc problems need help
    By R.thayer in forum Fanuc
    Last Post: 01-27-2007, 03:39 PM
  3. Fanuc 3TC problems
    By roni21702 in forum Fanuc
    Last Post: 03-15-2006, 06:00 AM
  4. Fanuc 3TC problems
    By roni21702 in forum DNC Problems and Solutions
    Last Post: 03-12-2006, 04:43 AM
  5. Fanuc Problems
    By scuba in forum MetalWork Discussion
    Last Post: 03-19-2005, 08:19 PM
