587,307 active members*
3,680 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Operator Message/Comment/Statement
Results 1 to 7 of 7
    Aug 2009
    684
    Hi all,
    Am running machine with Fanuc 31i, which is proving to be a powerful control, once you get to grips with it. Wondered if anyone knows how to get program to write a statement/message (a string that includes variables) into the 'Current Machining' or similar area of the 'Graphic' display. (Not just a (comment) in the program, and not an error message that will halt the cycle).
    I want this statement to appear at a certain point in the program, as a confirmation for the operator, and then clear itself. Other controls I have run have used MSG commands or similar to do this. I am new to Fanuc and have scoured the literature to no avail.
    Cheers,
    Dave
    2932
    I don't know about displaying a message without halting the cycle, but you could use a macro statement. It's limited to 26 characters, however. See attached.
    Feb 2006
    1792
    The execution would, however, restart after pressing CYCLE START.
    If you use system variable #3000, it would terminate the execution.
    Jun 2007
    119
    A possible solution
    This is possible by introducing in ladder
    Code:
    |  G 54.0                 A1.1
    G54.0 is for #1000 ,and put anywhere in the program #1000=1 which will generate alarm A1.1 without stopping machine .
    This is the basic idea ,you can put a timer to clear itself.
    Sorry for my English
    Feb 2006
    1792
    #1000 is read-only variable. You probably need to use #1100 and F-signal.
    Aug 2009
    684
    'Comment' G-Code
    Just in case anyone cares...
    This issue is resolved in Fanuc i series with G2900. I didn't have an i series manual, I found it by inputting codes randomly and checking descriptions.
    G2900 P_ (comment);
    Where P1 displays comment and P0 clears it.
    (Still haven't worked out if you can put a)#variable(in the string though...)
    Any ideas?
    DP
    Jan 2010
    96
    Hello, i have a training manual from Fanuc for the new 30 series i control. I will be happy to send you what i have if it will help. As you already know this is where Fanuc up and decided to change things for some reason and some things are a lot different than you are used to. Let me know your e-mail and i can send it to you. I havent sent anything via cnc zone yet so i dont know how large of a file we can send here but either way i can get it to you.
  1. Fanuc 6T - comment entry
    By bkelsey in forum Fanuc
    Last Post: 05-17-2023, 03:25 AM
  2. Using an IF statement inside a While looping
    By ggborgen in forum Parametric Programing
    Last Post: 06-23-2009, 06:40 PM
  3. Replies: 104
    Last Post: 02-24-2009, 03:18 PM
  4. Operator Message question for a 16I control
    By dougtyler in forum Fanuc
    Last Post: 11-11-2007, 01:59 AM
  5. Fanuc 11M alarm message
    By Moparmatty in forum DNC Problems and Solutions
    Last Post: 08-07-2007, 03:32 AM
