587,131 active members*
3,216 visitors online*
Thread: Fanuc OM-Ic
Results 1 to 9 of 9
    Feb 2008
    19
    Angry Fanuc OM-Ic
    Has anyone ever experienced the loss of machine zero reference points? Always seems to be Z zero and about 52>53 mm short of correct point, but no ALARMS caused major crash. This is driving me nuts as manufacturer says nothing can be done!!! 6 times now.
    Jun 2005
    232
    Maybe the cupling between the motor and the ball screw is lose ,mark it and see if its sliping.
    Tim
    Coupling loose - Switch moved - Switch broke.
    We cover the uk, check out our website, we fix Fanuc problems.
    The Fanuc Support Center Team
    www.fanuc-support.com
    Feb 2008
    19
    Checked them all, seems ok???? This fault is intermittent, runs fine for several weeks then just losses m/c "Z" zero.
    May 2007
    781
    When does it move? While machining or when homing after powerup.
    I wonder if the Z pulse on the encoder is happening too close to the same time the home switch is happening so that some times it goes to the next Z index pulse.
    Aug 2008
    153
    Z axis problem
    I think Andre is onto something. I'm curious, however, with such a new control, why you are needing to re-zero. If you have just encoders on the motors, I wouldn't think that the zeroing switch is ever getting used since everyone uses absolute encoders now.
    If you have linear scales, then you might be zeroing every day. Then, the marker pulse could, in fact, cause the axis to stop too close to the switch breaking point. Every so often, the switch could break in a slightly different place and cause a one grid (reference counter) jump.
    So, do you have scales?
    Warren
    www.uptimecorp.com
    Jun 2008
    1511
    I would first check to make sure everything is tight as Fanuc has stated. Encoder, switches, etc.
    If your reference marker is too close to the cam switch then it is possible that it will home in different positions. Although when this happens it will typically reference an exact amount different when it does 1 to the next. IOW when reference is normal it will be 0 and when it skips to the next pulse rev it will usually be exactly the same every time it changes. You may be 0 one time and 53mm off the next but never 54mm 52mm 53.5mm et. If you are to close you can do a gridshift.
    Stevo
    May 2007
    42
    Hi, tturnbull50!
    Move Home switch or dog(plate) to right or left 5~10mm.
    Good luck!
    Mar 2010
    0
    samples of programs
  1. GE Fanuc & FANUC proprietary posts
    By cncadmin in forum Fanuc
    Last Post: 01-12-2022, 07:33 PM
  2. FANUC & GE FANUC Repairs
    By RRL in forum News Announcements
    Last Post: 04-17-2011, 05:50 PM
  3. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
  4. Fanuc & GE Fanuc Repairs
    Last Post: 10-01-2008, 06:42 PM
