587,753 active members*
3,096 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Jul 2003
    69
    Fanuc OM Alarm 087
    Can anyone please explain what alarm 87 on a Fanuc OM means ?.
    Alarm 087
    When entering data in the memory by using Reader / Puncher interface, though the read terminate command is specified, input is not interrupted after 10 characters read.
    Our programs look like the following;
    O0010(ABC-123-ABC-A.123)
    (ABC-123-ABC-A.123)
    N10
    N20
    N30
    M30
    Aug 2007
    793
    Also manual says in alarm description "PCP or I/O unit defective
    There is another explanation of alarm 087 in attached PDF page
    If you need I can send you the total manual
    Attached Files Attached Files
    Jul 2003
    69
    Thanks, your version reads different from the manual we have.
    2932
    PS087 is Buffer Overflow. Your PC doesn't stop sending within the
    allotted time (10 characters) of receiving the XOFF.
    Check your Windows - Control Panel - System - Hardware - Device Manager - Ports - under Advanced there's FIFO Buffer settings. Slide them all the way to the left then uncheck "Use FIFO buffers".
    OK all the way out and then restart your PC to have the changes take effect. See if that does the trick.
    Aug 2008
    153
    Alarm 87
    I think your handshaking isn't working. Most people use software handshaking (Xon/Xoff) or also known as DC codes (DC1 through DC4). Handshaking is meant to stop the transfer until the control needs it.
    Some people use hardware handshaking to accomplish the same thing. If your cable has just three wires, it most certainly is set up for Xon/Xoff.
    Slowing down the baudrate on both ends can sometimes make enough difference so handshaking isn't needed, especially if you are just loading memory, not drip feeding.
    Warren
    www.uptimecorp.com
    May 2009
    181
    check the io settings.. and baudrates with the computer you are trying to communicate with..
    Iso=1
    if
    I/o channel is
    0 check parameter 2 bit 0 and 552
    1 check parameter 12 bit 0 and 553
    probably a bad setting.. computer setting four stop bits and baud rate must match
    Dec 2012
    71
    Re: Fanuc OM Alarm 087
    I have the same problem but there must be a difference because my file is small.
    I've downloaded the Parmeter file (very long) with no issues.
    I'm trying to change D0300 to 60000 for a timer value. I cannot do it manually so I thought, download it.
    The file has a few lines from D0300 to D0320 in steps if 5
    I get the alarm 087
    I think this has more to do with a restricted write than comms error.
    Mar 2013
    23
    marsheng, I have a very similar issue after setting up a DNC to USB device, to copy programs, I get 087 alarm. In my manual, after the "Buffer Overflow" part, there is the I/O unit or P.C.B. is potentially defective. Did you find a solution? Many thanks, in advance!
    Apr 2009
    1379
    "I think this has more to do with a restricted write than comms error" wrong, 087 alarm is never caused by that but always some form of comm issue.
    Mar 2013
    23
    memoryman, thank you. I have read a few more search responses now and there are several suggestions to lower baud rate to 4800 or lower. I did not check that on the PC software, but I will. Many thanks!!
    Mar 2013
    23
    I revisited the baud rate, set both (PC & mill) to 2400; extended the "time out" setting from 5000 to 65000. Nothing seemed to change the outcome, still 087 alarm. I looked at the memory board, all the places that memory attach (not like RAM in PC, look like pins out the back) are full. Suggestions are welcomed, many thanks, in advance.
    Apr 2009
    1379
    1: did the problem suddenly occur? what changed before that?
    2: what are your comm settings on the control and computer?
    Dec 2012
    71
    From memory I was writing 9000+ programs
    Once I change the parameter to give access, all worked.
    I also changed to a 5 wire serial cable from 3.
    One or 2 of the above fixed the problem.
    Apr 2009
    1379
    I also changed to a 5 wire serial cable from 3." this one.
    Mar 2013
    23
    marsheng & memoryman, thank you. The mill had no parameters and I received the parameters from the machine builder YCI, because the issue with rs232 port (or parameters) was only able to load parameters manually. This is a new to me mill, I had a close friend that pancreas cancer took away too soon, who was my lifeline with this type of question. The cable is the cable that came with the DNC to CNC device, it has 9 pin female to 25 pin male rs232. It will copy from "Program" (stored in library O0001) is attached file, before and after being in the mill. This is a fake part, needed a file that had motion & drill operation.
    I used an ohm meter to tease out if the rs232 was good by starting with female 9 pin with 1 end of the meter; was the MO5 plug in electrical cabinet, only 4 wires are used. The PC comm settings are: software; 4800 baud, 7 bits, even parity, stop bit 2.
    The parameters are here:
    I / O=1
    002 01100111
    012 01000001
    038 10101000
    050 10000011
    051 00000011
    251 00000010
    552 00000010
    553 00000010
    Suggestions are welcomed. Many, many thanks, in advance.
    Dec 2012
    71
    I presume you have the parameters in a file.
    From memory, I had to enter P0900 and P0901 parameters manually and then I could load via the serial port. (Special Parameters go from 0900 to 0932)
    My machine settings was 4800 E 7 bits 2 stop bits.
    It appeared to me that loading parameters worked fine with 3 wire but programs needed 5. I could be wrong.
    I used Realterm for communications. It tells you what the machine replies. Need to set as shown
    Attachment 491898
    Attachment 491900.
    Dec 2009
    972
    you can also load programs with 3 wires
    the 5 wires setup is need it when you drip feed direct from PC a.k.a. DNC mode
    Mar 2013
    23
    I want to thank everyone, as marsheng has stated parameters 901.6 & 914.4 need set to be correct. I have not tested the cable (my cable is from the DNC kit, I fully expect it to work) to see if 3 or more wire required for drip feed, my concern was the ability to copy programs to memory. When these parameters are edited, it requires the programs in memory to be deleted, BTW. Many thanks!
    Apr 2023
    2
    Guys Keanan here from South Africa Im 24 years old and Im battling to remove a tl-cp or mg-l abnormal alarm from my Fanuc OM series cnc mill
    Really need advice or guidance on how to remove this alarm or fix the problem
    Its very difficult to fing guys who can assist with this problem
    Dec 2012
    71
    Has this anything to do with alarm 087 ?
Page 1 of 2 12
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Fanuc 6T-B alarm 402:servo Alarm
    By leiryll in forum Fanuc
    Last Post: 12-03-2013, 08:52 AM
  4. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  5. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
