I've been struggling :boxing: with a Bridgeport VMC machine with a Fanuc 11M controller for a long time.
the motherboard was changed because apparently it had a problem (not booting at all),
after the change the machine boots but shows an alarm as if all limit switches were tripped.
my guess was that the IO module had a fail, then replaced it but no change.
finally I read that i have to check the optic fibers and if there are the IR signals.
i test that using an infrared camera and could see a solid IR lights coming out from motherboard and IO module. Now I don't know what else to check.
Jorge B.
