587,900 active members*
3,187 visitors online*
Results 1 to 18 of 18
    Fanuc G84 rigid tapping code
    Hi, I'm doing some rigid tapping using the fanuc G84 code and was hoping someone could help me out. After tapping a hole it pauses for 3 to 4 seconds before moving to the next hole. Does not seem like a long time but it feels like an hour when your doing production. I just started using the funuc post processor in fusion 360 and hopefully I can fix this. Any help would be appreciated.
    Thank you,
    Jack
    Dec 2013
    5716
    Re: Fanuc G84 rigid tapping code
    Can you post a G code snippet, a few lines before and after a G84 cycle.
    Jim Dawson
    Sandy, Oregon, USA
    Quote Originally Posted by Jim Dawson View Post
    Here you go. It's 8 holes tapping.
    (DRILL9)
    N800 M09
    N805 M01
    N810 T5 M06
    N815 S400 M03
    N820 G04 X3
    N825 G54
    N830 M08
    N840 G00 X3.1819 Y-3.1819
    N845 G43 Z0.2 H05
    N450 M29 S400
    N855 G84 X3.1819 Y-3.1819 Z-0.75 R0.2 P0 F20.
    N860 X2.7134 Y-2.7134
    N865 X1.1092 Y-2.9565
    N870 X0.2318 Y-3.0686
    N875 X0.3535 Y-0.3535
    N880 X0.7866 Y-0.7866
    N885 X3.036 Y-1.0296
    N890 X3.07 Y-0.25
    N895 G80
    N900 G00 Z0.2
    N910 M09
    N915 G28 G91 Z0.
    N920 G49
    N930 M05
    N935 M30
    Thank you,
    Jack
    Dec 2013
    5716
    There is nothing in the G code that would cause the delay. Best guess there is a machine setting that is causing the delay. Something like ''Wait for Spindle Speed Delay'' or something like that. Could be that the spindle is reorienting before continuing on.
    Jim Dawson
    Sandy, Oregon, USA
    Thank you Jim for taking a look. I did not see anything either but another set of eyes is always a valuable asset. I agree it may be in the machine controller as a delay for all the stars to get aligned before making it's next move.
    Jack
    Apr 2012
    79
    You could try putting a M19 spindle orient before the M29 Line. It might not help but I use it every time.
    N845 G43 Z0.2 H05
    N846 M19
    N450 M29 S400
    Feb 2006
    1792
    Try G99 G84 instead.
    Sep 2012
    4
    Dunno about your control but here is a few things to check.
    1. the N450, make it to N850.. ( it shouldnt make a difference, if it does.. some of your parameters sux in your control)
    2. try to write the whole G84 block for the next hole, as you got in line N855.
    3. if you use Fusion360 check out what code comes out of it. Sometimes a M-code (that you run) might mess up things bad.
    4. If you use some codes above this snippet of code, be sure they are all set back to 'machine start state'. Like turn on / turn off things.
    .... if you turn on something (change it from 'machine power on state') put it back to what it was. (Talking group codes here)
    1 question tho. Did the machine do this in the past or not?
    I wish you find something useful of all the answers you got from ppl here. =)
    Cheers,
    Mikie
    Mar 2017
    314
    maybe it all those block numbers. LOL!
    have you tried ipr feed? G95
    Do not forget to change it back, you'll crap yourself.
    Feb 2018
    4
    Try removing line N815 you don't need it as spindle speed is defined by the M29 in line N450. This will cause a delay as the spindle is rotating then has to stop and orientate before tapping the hole.
    Feb 2006
    1792
    M03 is unnecessary in rigid tapping.
    Oct 2015
    215
    Quote Originally Posted by sinha_nsit View Post
    My machine with a Fanuc Mate actually throws a error if I include a speed command (S) with the M03. The Fanuc post processor includes it tho so I have to manually remove it after each post..No idea if that solves anything for you tho ^*
    Quote Originally Posted by m1n1m View Post
    Thanks everyone for your help, the S400 and M03 above the M29 line was a big factor in the slowness for sure. With the M29 line the M03 is unnecessary. I had been using the S400 with the M03 with no issues or errors.
    Jack
    Oct 2015
    215
    Let me know if you figure out how to remove this line before a rigid tap cycle. These are modal codes so I assume they have to be reset somehow before a rigid tap cycle. Will poke some at my post processor in a few days and see if I can figure out something.
    I have no idea what your talking about. Why don't you give me the tapping g code example.
    Feb 2006
    1792
    He is probably saying that the spindle is already running.
    Oct 2015
    215
    Quote Originally Posted by Roadstercycle View Post
    I just assumed that you didn't want to manually edit your gcode after each post containing a rigid tap cycle so you wanted to edit the post processor to leave out M03 SXXX. Also if you had a S commanded earlier in the program it's modal (I think) so it will remain until set to another value. I just tested this the other day on my machine so I'm not very experienced with this.. There's not much of an example to give really. Your code will be good as long as M03 SXXX command is dropped on my machine but this is a bit machine dependent so it's not set in stone what format it needs.
    I manually do my coding. If I do use Fusion 360 then I tweak it. It's no big deal for me because I use the same code a lot. So it is stored.
  1. Another Fanuc OM Rigid Tapping Question
    By ArsenalProducts in forum Fanuc
    Last Post: 02-16-2017, 11:02 AM
  2. Fanuc 18-M alarm when rigid tapping
    By pufferfish in forum Fanuc
    Last Post: 05-23-2016, 06:37 PM
  3. Fanuc OM Rigid Tapping
    By Saumurea in forum Community Club House
    Last Post: 09-23-2013, 07:39 PM
  4. Fanuc OTC rigid tapping help
    By 47MLB in forum Fanuc
    Last Post: 03-07-2010, 06:24 PM
  5. Need help with rigid tapping code.
    By rbcmetalwork in forum Sharp CNC
    Last Post: 11-17-2009, 05:54 AM
