587,645 active members*
3,113 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc controls outputting double spaces
Results 1 to 7 of 7
    Dec 2009
    9
    i have a fanuc 21i MB control, a fanuc Oi - TC and a fanuc Oi - TB control and when I punch out a program to card it places double spaces between every line. Can anyone HELP,
    Aug 2008
    153
    Double Line Feeds
    Here is parameter 70.7 for the 0MC control:
    ICR
    1 : EOB is punched out as “LF when punching with IS0 code.
    0 : EOB is punched out as “LF” “CR” “CR” when punching with IS0 code.
    There is a similar one for the 21 control too.
    Warren
    www.uptimecorp.com
    2932
    On the 0i, 18i, 21i, (and probably the 16i) it's parameter 100 bits 2 and 3.
    7 6 5 4 3 2 1 0
    x x x x 0 0 x x = LF CR CR (double spaced)
    x x x x 0 1 x x = CR LF
    x x x x 1 0 x x = LF
    x x x x 1 1 x x = CR LF
    Yours is probably set to 00. Change it to 01 or 11, and you should be good to go.
    Nov 2006
    418
    Quote Originally Posted by WGoyer View Post
    ICR
    Warren
    www.uptimecorp.com
    Thanks for that info - I couldn't find that setting and it has been driving me nuts!
    Dec 2009
    9
    Quote Originally Posted by dcoupar View Post
    7 6 5 4 3 2 1 0
    Thanks, this worked a treat, worked on all my controls.
    Jan 2007
    8
    Re: Double Line Feeds
    Hi I have a fanuc ot that is double spacing also what is parameter 70.7 not in either of my controls also have a omc?? looking for eob parameter to set to line feed only thanks
    Aug 2008
    153
    Capt Bob,
    The parameter 0070, bit 7 (the one on the far left) listed in the 0MC Parameter manual is to control whether the control outputs LF (line feed) or LF AND CR( carriage return) in ISO outputs. Are you saying that you don't have parameter 70? I just checked both the 0MC and the 0MT books, and parameter 70 is only described in detail in the 0MC book. This implies that some vintages of lathe controls may have this parameter in a different place.
    Warren
    Uptime Electronics, Inc.
  1. fanuc g73 ot controls
    By Fire_Fly666 in forum Fanuc
    Last Post: 07-16-2010, 09:52 AM
  2. Fanuc 18iM, outputting variables
    By Mika M. in forum Fanuc
    Last Post: 05-24-2010, 06:11 AM
  3. Outputting programs from Fanuc 10M
    By jakeb in forum Fanuc
    Last Post: 02-27-2009, 02:21 AM
  4. Outputting programs from Fanuc MV-40B
    Last Post: 02-23-2009, 05:17 PM
  5. fanuc 21i double turret
    By nabil_elbadri in forum Fanuc
    Last Post: 01-12-2008, 06:08 AM
