Trying to learn myself about this old control, of course that naturally means screwing things up and trying to figure out how to undo the screw up.
Machine is a ~1984-85 Okuma Millac MC-4VA with a Fanuc 6M-B control
Was trying to get machine to home all axis and I went too far on X and hit the hard limit, the hard limit must be part of the E-stop circuit because when it tapped that limit switch my "machine ready" light immediately shut off as if I'd hit the E-stop. If I hold the "machine ready" button that normally turns all the subsystems (servo amps, lube pump, hydraulics, spindle drive) the light comes on but "servo error 401" shows up on the alarm screen. With error 401 up, the servo amps will not reset (and hitting the "reset" button causes the alarm to disappear for a couple seconds then immediately reappear) as such I can't jog the table in the opposite direction so that it gets off the hard limit switch.
Some googling suggests restarting the control while holding P+cancel buttons down which didn't appear to do anything. I have to wonder if the hard limit switches are somehow tied into the servo amps, unfortunately this machine didn't come with wiring diagrams to tell me if or how.
Is there an easier way to do this than unbolting and disconnecting the axis servo motor and rotating it until its off the limit switch? Or disconnecting the hard limit long enough to jog it back to center? I can do either if necessary but it seems like more work than it ought to be. Elsewhere I've been advised to just move the screws with servos off which works fine for X/Y but not Z, as Z has a servo brake and will not move unless power is applied to loosen it.
Wondering also what my options are to drip feed programs to this machine, how much do I have to spend to make it do what I want?
Last question, is there a procedure or call to make the machine automatically home itself? I'm a fanuc n00b all my CNC experience has been with a LinuxCNC retrofitted machine.
