Wondering if anyone can help when in mdi I want to move to my workoffsett but machine reads in incremental in mdi not absolute?
G90 change it to absolute and G91 to incremental. So G90 G54 should move it in absolute to your work offset.
G90 Doesn't work in mdi so I think its a parameter
3401 bits 4 (MAB) and 5 (ABS)
MAB Switching between the absolute and incremental commands in MDI
operation
0 : Performed by G90 or G91
1 : Depending on the setting of bit 5 (ABS) of parameter No.3401
ABS Program command in MDI operation
0 : Assumed as an incremental command
1 : Assumed as an absolute command
ok so changed the parameter it works but now there is no points in numbers on tool length and work offsets?
